Stupid Elevator Trim Tab Tricks
Posted: Fri Feb 17, 2012 11:08 pm
Wayne - I took a look at your idea and it is pretty good - the only thing is
the Elevator is 2.5" thick and the servo shaft is about 5/8" down off the
surface - It might put some extra angle on it which I am hesitant to do - I'll
draw it up to see how the hole in the skin lays out - How much trim tab
up/down deflection do you expect to see?
Thanks -- Britt
-> Keep breathing that alum dust Britt and you might forget sooner than you
-> think!!
-> I'll have to go back out in the shop and stare at the one I have here. Not
-> sure how the trim unit is going to function correctly with the tabs hinge at
-> the bottom as well. Still think flipping it over and then maybe move the
-> trim motor to the (new) bottom skin so the rod comes out the bottom and the
-> hinge is now on the top skin (but on the right side!). Have you even mounted
-> the tab motor yet??
-> Wayne
-> From: "Reed, Britt/FSC Salt Lake" <BReed@slcrail.com>
-> Sent: Friday, May 30, 2003 6:29 PM
-> Subject: RE: Stupid Elevator Trim Tab Tricks
-> > That is good and believe me I may! But then I have all those inspection
-> > ports and the trim tab shaft up on top.
-> > Maybe I'll leave it as it is and put a gap seal on the top side - Any
-> > ideas??
-> > Probably just end up bending a couple more ribs for the relocated trim tab
-> > horn and leave it as is.
-> > At this rate Alzheimer's will set in before I finish and I won't know the
-> > difference.
-> > Britt SR194
-> > From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
-> > Sent: Friday, May 30, 2003 3:25 PM
-> > To: murphy-rebel@dcsol.com
-> > Subject: Re: Stupid Elevator Trim Tab Tricks
-> > Well that sucks Britt!!
-> > BUT the elevator is pretty much concentric on the SR???
-> > Flip the sucker over, make sure it fits your stab hinges and then you'll
-> > have your trim tab on the right side. Don't make no difference really and
-> a
-> > lot better solution that starting over again!!
-> > Wayne
-> > From: "Reed, Britt/FSC Salt Lake" <BReed@slcrail.com>
-> > To: <murphy-rebel@dcsol.com>
-> > Sent: Friday, May 30, 2003 6:00 PM
-> > Subject: Stupid Elevator Trim Tab Tricks
-> > > Ever had a sinking feeling right before you finish something - I have
-> the
-> > > elevator trim tab ready to rivet and thought it was strange that I have
-> > the
-> > > hinge on the bottom of the elevator (per the plans Figure 3.5.7) and I
-> > > remember seeing the hinge on the top surface - Duhh - I asked Brian if
-> > > anyone else had made that mistake and he said maybe but no one has
-> > admitted
-> > > it.
-> > > One afternoon at Cheers, Cliff Clavin was explaining the Buffalo Theory
-> to
-> > > his buddy Norm. Here's how it went: "Well ya see, Norm, it's like
-> this...A
-> > > herd of buffalo can only move as fast as the slowest buffalo. And when
-> the
-> > > herd is hunted, it is the slowest and weakest ones at the back that are
-> > > killed first. This natural selection is good for the herd as a whole,
-> > > because the general speed and health of the whole group keeps improving
-> by
-> > > the regular killing of the weakest members. "In much the same way, the
-> > human
-> > > brain can only operate as fast as the slowest brain cells. Excessive
-> > intake
-> > > of alcohol, as we know, kills brain cells. But naturally, it attacks the
-> > > slowest and weakest brain cells first. In this way, regular consumption
-> of
-> > > beer eliminates the weaker brain cells, making the brain a faster and
-> more
-> > > efficient machine. That's why you always feel smarter after a few
-> beers."
-> > > Maybe I need more beer -
-> > > To unsubscribe from this list go to:
-> > > http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> > > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
-> > > To contact the list admin, e-mail mike.davis@dcsol.com
-> > To unsubscribe from this list go to:
-> > http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
Thanks -- Britt
-> think!!
-> Wayne
-> > ideas??
-> > difference.
-> > Britt SR194
-> a
-> > Wayne
-> the
-> > the
-> > admitted
-> > > it.
-> to
-> this...A
-> the
-> by
-> > human
-> > intake
-> of
-> more
-> beers."
