Stupid Elevator Trim Tab Tricks
rebel
Post by rebel » Fri Feb 17, 2012 11:08 pm
Wayne - I took a look at your idea and it is pretty good - the only thing is
the Elevator is 2.5" thick and the servo shaft is about 5/8" down off the
surface - It might put some extra angle on it which I am hesitant to do - I'll
draw it up to see how the hole in the skin lays out - How much trim tab
up/down deflection do you expect to see?
Thanks -- Britt
-> Keep breathing that alum dust Britt and you might forget sooner than you
-> think!!
-> I'll have to go back out in the shop and stare at the one I have here. Not
-> sure how the trim unit is going to function correctly with the tabs hinge at
-> the bottom as well. Still think flipping it over and then maybe move the
-> trim motor to the (new) bottom skin so the rod comes out the bottom and the
-> hinge is now on the top skin (but on the right side!). Have you even mounted
-> the tab motor yet??
-> Wayne
-> From: "Reed, Britt/FSC Salt Lake" <BReed@slcrail.com>
-> Sent: Friday, May 30, 2003 6:29 PM
-> Subject: RE: Stupid Elevator Trim Tab Tricks
-> > That is good and believe me I may! But then I have all those inspection
-> > ports and the trim tab shaft up on top.
-> > Maybe I'll leave it as it is and put a gap seal on the top side - Any
-> > ideas??
-> > Probably just end up bending a couple more ribs for the relocated trim tab
-> > horn and leave it as is.
-> > At this rate Alzheimer's will set in before I finish and I won't know the
-> > difference.
-> > Britt SR194
-> > -----Original Message-----
-> > From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
-> > Sent: Friday, May 30, 2003 3:25 PM
-> > To: murphy-rebel@dcsol.com
-> > Subject: Re: Stupid Elevator Trim Tab Tricks
-> > Well that sucks Britt!!
-> > BUT the elevator is pretty much concentric on the SR???
-> > Flip the sucker over, make sure it fits your stab hinges and then you'll
-> > have your trim tab on the right side. Don't make no difference really and
-> a
-> > lot better solution that starting over again!!
-> > Wayne
-> > ----- Original Message -----
-> > From: "Reed, Britt/FSC Salt Lake" <BReed@slcrail.com>
-> > To: <murphy-rebel@dcsol.com>
-> > Sent: Friday, May 30, 2003 6:00 PM
-> > Subject: Stupid Elevator Trim Tab Tricks
-> > > Ever had a sinking feeling right before you finish something - I have
-> the
-> > > elevator trim tab ready to rivet and thought it was strange that I have
-> > the
-> > > hinge on the bottom of the elevator (per the plans Figure 3.5.7) and I
-> > > remember seeing the hinge on the top surface - Duhh - I asked Brian if
-> > > anyone else had made that mistake and he said maybe but no one has
-> > admitted
-> > > it.
-> > > One afternoon at Cheers, Cliff Clavin was explaining the Buffalo Theory
-> to
-> > > his buddy Norm. Here's how it went: "Well ya see, Norm, it's like
-> this...A
-> > > herd of buffalo can only move as fast as the slowest buffalo. And when
-> the
-> > > herd is hunted, it is the slowest and weakest ones at the back that are
-> > > killed first. This natural selection is good for the herd as a whole,
-> > > because the general speed and health of the whole group keeps improving
-> by
-> > > the regular killing of the weakest members. "In much the same way, the
-> > human
-> > > brain can only operate as fast as the slowest brain cells. Excessive
-> > intake
-> > > of alcohol, as we know, kills brain cells. But naturally, it attacks the
-> > > slowest and weakest brain cells first. In this way, regular consumption
-> of
-> > > beer eliminates the weaker brain cells, making the brain a faster and
-> more
-> > > efficient machine. That's why you always feel smarter after a few
-> beers."
-> > > Maybe I need more beer -
-> > > To unsubscribe from this list go to:
-> > > http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> > > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
-> > > To contact the list admin, e-mail mike.davis@dcsol.com
-> > http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
Post by Reed, Britt/FSC Salt Lake » Fri Feb 17, 2012 11:08 pm
Ever had a sinking feeling right before you finish something - I have the
elevator trim tab ready to rivet and thought it was strange that I have the
anyone else had made that mistake and he said maybe but no one has admitted
it.
One afternoon at Cheers, Cliff Clavin was explaining the Buffalo Theory to
his buddy Norm. Here's how it went: "Well ya see, Norm, it's like this...A
herd of buffalo can only move as fast as the slowest buffalo. And when the
because the general speed and health of the whole group keeps improving by
the regular killing of the weakest members. "In much the same way, the human
brain can only operate as fast as the slowest brain cells. Excessive intake
slowest and weakest brain cells first. In this way, regular consumption of
beer eliminates the weaker brain cells, making the brain a faster and more
efficient machine. That's why you always feel smarter after a few beers."
ideas??
difference.
Britt SR194
have your trim tab on the right side. Don't make no difference really and a
admitted
it.
human
intake
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:08 pm
admitted
it.
human
intake
think!!
the tab motor yet??
ideas??
difference.
Britt SR194
admitted
it.
this...A
by
human
intake
more
beers."
Bill Delcambre
Post by Bill Delcambre » Fri Feb 17, 2012 11:08 pm
I just can't get over how helpful this list really is! This is probably
some of the deepest and most useful thinking that I've ever seen.
Man, can I use this line.....
Bill
Excessive intake of alcohol, as we know, kills brain cells. But naturally,
it attacks the
