G'day Frank !
I'm just about to make & fit a 4 into 1 exhaust system for our IO -
320 in Rebel 541R .... could you please send me the photos of the Swiss
muffler.
Rick & Wendy Harper
rjwh@ozemail.com.au
paco@dcsol.com
To:
murphy-rebel@dcsol.com
Sent: Wednesday, May 28, 2003 11:28 PM
Subject: RE: swiss muffler
Hope this can help.
I started flying with gliders, so for me, quieter is better!
I have installed a 36" swiss muffler on 0145R and is working well
so far!
Very quiet on the ground and in flight. Just one word of warning, the
swiss
muffler can be made with an aluminum outer shell that is seamed
together. If
the engine you are using has large exhaust pulses, and the muffler
attached to
solid to the exhaust, it can split the seam open.
I gained 150RPM static when I switched from a single SuperTrapp to
Swiss so I guess the EA-81 was asking for a bit more back pressure. I
didn't
drop bolts through the floor, I installed a 4"x6" 1/8" thick aluminum
plate to
the underside of the aircraft and used 2 timing belt rubber straps for
vibration damping at rear. On the front I installed a rather expensive
stainless braided flex coupling from the local autoparts store. You
have to
ensure that the engine exhaust and Swiss muffler have plenty of flex
between
them or it will rip the Swiss Muffler to bits. I can send pic's if you
are
interested.
Frank
On 5/28/2003 5:13 AM, LATER wrote to
HDICK@IAW.ON.CA:
-> I've been looking at it with interest. Main concern was how to
insure that
it
-> stays on. Don't know anyone that's done it. later
-> On 5/27/2003 1:30 PM,
HDICK@IAW.ON.CA wrote to MURPHY-REBEL:
-> -> From <
hdick@iaw.on.ca> Thu, 22 May 2003 11:57:25 -0800 remote
from
-> dcsol.com
-> -> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.61)
-> -> for
murphy-rebel@dcsol.com; Thu, 22 May 2003 11:57:25
-0800
-> -> Received: from canal.iaw.on.ca ([209.5.112.33])
EHLO=canal.iaw.on.ca
-> -> by dcsol.com (Wildcat! SMTP v5.6.450.61) with SMTP
-> -> id 1370750671; Thu, 22 May 2003 11:57:24 -0800
-> -> Received: from as4-13.iaw.on.ca ([209.5.117.152] helo=hdick)
-> -> by canal.iaw.on.ca with smtp (Exim 4.05)
-> -> id 19IwBj-0003wP-00
-> -> for
murphy-rebel@dcsol.com; Thu, 22 May 2003 15:57:20 -0400
-> -> Message-ID: <001001c3209c$a99afe40$987505d1@hdick>
-> -> From: "Harold Dick" <
hdick@iaw.on.ca>
-> -> To: <
murphy-rebel@dcsol.com>
-> -> Subject: swiss muffler
-> -> Date: Thu, 22 May 2003 15:59:30 -0400
-> -> X-Orig-MIME-Version: 1.0
-> -> X-Orig-Content-Type: multipart/alternative; boundary="----
-> =_NextPart_000_000D_01C3207B.2162DFA0"
-> -> X-Priority: 3
-> -> X-MSMail-Priority: Normal
-> -> X-Mailer: Microsoft Outlook Express 5.00.2615.200
-> -> X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2615.200
-> -> Has anyone tried or heard of anyone experimenting with the Swiss
style
-> -> muffler system on an engine as large as an O-320?
-> -> Harold Dick
-> -> 633E
Archives located at
To contact the list admin, e-mail
mike.davis@dcsol.com
Archives located at
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
