high speed drill
Posted: Fri Feb 17, 2012 11:02 pm
The drill I am looking at getting is 2800 RPM... but that's the fastest I've
found for a "reasonably" priced one... I saw a couple at 3200 and 3600 at over
3 times the price. The 13,000 - 17,000 rpm drill is only $85 from Aircraft
Spruce... just doesn't seem right.
On 5/19/2003 8:46 PM, MURPHY-REBEL@DCSOL.COM wrote to MIKE DAVIS:
-> Hi Mike !
-> I think the 'cleaner hole' thing was based on local experiences
-> with 6,000 rpm air drills - that being a 'standard' (???) speed that
-> was readily available ....
-> 13,000 - 17,000 rpm !!!! Wooooow !!! Sounds like a
-> screamer !!
-> Only cautionary note I've heard about the faster drills -
-> "They're fast & light, and do produce a clean hole, BUT ......
-> they make a GREAT ROUTER if you're not VERY careful, and quick with
-> the OFF button !" ;-) ;-^) :-) ;-)
-> Might be very handy for oval holes - like skylights !! ;-^)
-> .....bobp
-> -------------------------------orig.---------------------------------
-> At 05:01 PM 5/19/03 -0800, you wrote:
-> >In the past it has been discussed that the faster your drill, the cleaner
-> >the holes, and the easier it is to debur. Well has anybody used the
-> >"pneumatic high speed drill" that Aircraft Spruce is offering with
operating
-> >speeds of 13,000 - 17,000 RPM. Check it out here:
-> >http://www.aircraftspruce.com/catalog/t ... tdrill.php
-> >The drill I was looking at runs at 2800 RPM, but then I stumbled across the
-> >one above... I would imagine that it doesn't have much torque, but thought
-> >it was worth looking at. I built my stab just using my electric drill
(2500
-> >RPM), but it gets aweful heavy after a while. Now with father's day coming
-> >up, a nice pneumatic drill is just the ticket for a present from my family.
-> >Thanks, Mike
-> Hi Mike !
-> screamer !!
-> .....bobp
operating
(2500
-> >Thanks, Mike
