V8 Ignition
John Worden/Nancy Bulman
V8 Ignition
Post by John Worden/Nancy Bulman » Sat Feb 18, 2012 2:02 am
Mike,
MSD sells a number of items for a dual ignition setup. They have a dual
magnetic pickup distributor (#8356), an automatic coil selector (#8210),
and a wire harness and switch to allow the use of redundant ignition
amplifiers. I plan to run my second ignition amplifier from a small backup
battery. The automatic coil selector is a package of diodes so that when
you switch to your backup ignition amp the spark then is routed from your
second coil as well. This at least keeps you from falling out of the sky
due to one transistor.
Jegs has the MSD distributor as well as the other parts. The switch and
harness I could not find this go round.....
http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
John
