Dorsal Fin installation
Received: from fwd05.btx.dtag.de (fwd05.btx.dtag.de [194.25.2.165])
by mailout07.btx.dtag.de with smtp
id 107PQY-00037u-00; Mon, 1 Feb 1999 20:54:34 +0100
Received: (068612707-0001(btxid)@[193.159.7.175])
by fwd05.btx.dtag.de
id <m107PPa-0003HCC>; Mon, 1 Feb 1999 20:53:34 +0100
Message-Id: <m107PPa-0003HCC@fwd05.btx.dtag.de>
Date: Mon, 1 Feb 1999 20:53:34 +0100
Subject: Dorsal Fin installation
X-Mailer: T-Online eMail 2.2
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8BIT
X-Sender: 068612707-0001@t-online.de
From: Johannes.Laubenthal@t-online.de (Johannes Laubenthal)
Hi !
Does anybody has already installed a dorsal fin for the rebel? I have a
prefolded skin in my Kit but no information to install it . What about an
offset (FIN about 3/4 inch for Lycoming engine)? What rivet space to attach
the Tailskin? What rivet space and where to attach it to the FIN ? Sanding
cutting out) edge of the dorsal fin or sanding (cutting out) leading edge of
FIN in order to put the parts together??
Johannes Laubenthal R 603
MIME-Version: 1.0
Hi !
Received: from dialup.voyager.co.nz (ts1p07.net.ashburton.voyager.co.nz
[203.21.25.171]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
JAA08735 for <murphy-rebel@dcsol.com>; Tue, 2 Feb 1999 09:39:25 +1300 (NZDT)
Message-Id: <199902012039.JAA08735@host02.net.voyager.co.nz>
Subject: Re: Dorsal Fin installation
Date: Tue, 2 Feb 1999 09:39:09 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Hi there,
I fitted a dorsal fin to my Rebel, as with you there were no instructions
so I just charged ahead.
With the 0-320 I offset my fin 3/4", it has turned out spot on in flight. I
then paralleled the fuse forward from there with the dorsal fin, it seemed
the only logical thing to do with it.
Rivet spacing on the fuse of around an 1 1/4" seemed to be OK, if I ran
over the top of any other existing rivets I removed and dimpled them, and
put in coutersunk rivets. I attached the dorsal fin to the vertical fin
just forward of the rivet line that attaches the leading edge of the
vertical fin. I put a little peice of rubber type edging around the top
where the dorsal fin joins the vertical fin.
I did find it was quite difficult to keep the dorsal fin symetrical because
of the small bend from the offset of the vertical fin, so I used a thick
peice of foam rubber to pack out the dorsal fin, I left it in there.
Hope this helps.
Alister
X-Priority: 3
MIME-Version: 1.0
Hi there,
Hope this helps.
Alister
From: Johannes Laubenthal <Johannes.Laubenthal@t-online.de>
Date: Tuesday, February 02, 1999 8:53 AM
Hi !
attach tooffset (FIN about 3/4 inch for Lycoming engine)? What rivet space to
Sanding (the Tailskin? What rivet space and where to attach it to the FIN ?
of thecutting out) edge of the dorsal fin or sanding (cutting out) leading edge
Received: from [137.186.230.224] (helo=ms03-224.tor.istar.ca)
for murphy-rebel@dcsol.com
id 107RHi-0004Yu-00; Mon, 1 Feb 1999 16:53:35 -0500
Mime-Version: 1.0
Message-Id: <E107RHi-0004Yu-00@mail2.toronto.istar.net>
Date: Mon, 1 Feb 1999 16:53:35 -0500
The dorsal fin should be straight down the middle of the fuselage -
several builders have NOT offset the vertical fin, either. (The offset
is only good for ONE speed and power setting anyway, and it is a LOT
easier to install the fin without the offset ! A tab on the rudder takes
care of adjustment, if required.)
Rivet spacing similar to that used on the skins at the bulkheads
should do. DO NOT cut the leading edge of the vertical fin - it's
structural. The dorsal fin is strictly cosmetic - it's not even needed
aerodynamically. A strip of rubber 'U' channel around the end of the
dorsal fin should keep it tight to the vertical, without allowing it
to saw into the vertical leading edge.
HTH .....bobp
-----------------------------orig.-------------------------------------
At 08:53 PM 2/1/99 +0100, you wrote:
Mime-Version: 1.0
HTH .....bobp
toHi !
Received: from tim-toshiba - 206.40.8.15 by email.msn.com with Microsoft
SMTPSVC;
Mon, 1 Feb 1999 14:01:51 -0800
Reply-To: <tlcarter@email.msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Dorsal Fin installation
Date: Mon, 1 Feb 1999 14:03:56 -0800
Message-ID: <000101be4e2e$c8731540$14640a0a@tim-toshiba>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Importance: Normal
In-Reply-To: <E107RHi-0004Yu-00@mail2.toronto.istar.net>
Return-Path: tlcarter@email.msn.com
Bobp:
Is that a recommendation against what the instruction manual says about
offsetting the vertical stab? It seems to me that a tab would almost
certainly be required if there were no preset offset....
Do you know of any big engine Rebels (O-320) that have no offset? How much
tab is required in terms of size?
Curious....
Tim
Sent: Monday, February 01, 1999 1:54 PM
To: Murphy Rebel
HTH .....bobp
SMTPSVC;
MIME-Version: 1.0
Importance: Normal
Bobp:
Curious....
Tim
To: Murphy Rebel
HTH .....bobp
toHi !
id 107S0f-0007cB-00; Mon, 1 Feb 1999 17:40:02 -0500
Mime-Version: 1.0
Message-Id: <E107S0f-0007cB-00@mail2.toronto.istar.net>
Date: Mon, 1 Feb 1999 17:40:02 -0500
Just a suggestion - had several long discussions with Mike Davey when
he was building his Rebel. He decided NOT to offset the fin, because
any offset is only effective at ONE speed and power setting, and because
installing the fin with the offset was a pain in the attach bolt area.
It is working very well, and he didn't need a tab for his O-235.
I have a tab on my 912 Rebel (which has no offset). The tab is about
4 " long, and about 2" wide, and is bent over about 1/4" - this is too much
Some of the P-factor considerations are already handled in the
engine mount offset, and this can be adjusted with washers, if needed.
Mike is no lightweight - he retired as Vice-President of Engineering
at De Havilland a few years ago, and is currently building his own
custom designed aircraft. He put considerable thought into his decision,
and it seems to be satisfactory.
Some other considerations were - the problems if you offset TOO FAR,
and the possibility of changing to an engine that turned in the OPPOSITE
direction, sometime later....
--------------------------------orig.----------------------------------
Mime-Version: 1.0
attachBobp:
Curious....
Tim
To: Murphy Rebel
HTH .....bobp
At 08:53 PM 2/1/99 +0100, you wrote:Hi !
toSanding (the Tailskin? What rivet space and where to attach it to the FIN ?of thecutting out) edge of the dorsal fin or sanding (cutting out) leading edgeFIN in order to put the parts together??
Received: from dialup.voyager.co.nz (ts1p15.net.ashburton.voyager.co.nz
[203.21.25.179]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
MAA16712 for <murphy-rebel@dcsol.com>; Tue, 2 Feb 1999 12:01:36 +1300 (NZDT)
Message-Id: <199902012301.MAA16712@host02.net.voyager.co.nz>
Date: Tue, 2 Feb 1999 12:01:58 +1300
X-Priority: 3
MIME-Version: 1.0
If I had to do mine again I would still leave the 3/4" offset in with the
0-320 motor, I put a trim tab on the rudder in anticipation of needing one,
its now sitting there with no bend in it at all, the set up is near to
perfect.
Alister
X-Priority: 3
MIME-Version: 1.0
perfect.
Alister
much !From: Bob Patterson <bob.patterson@canrem.com>
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Tuesday, February 02, 1999 11:40 AM
muchSome of the P-factor considerations are already handled in the
At 02:03 PM 2/1/99 -0800, you wrote:Bobp:
antab is required in terms of size?
Curious....
Tim
To: Murphy Rebel
HTH .....bobp
attachoffset (FIN about 3/4 inch for Lycoming engine)? What rivet space to
edgetoSanding (the Tailskin? What rivet space and where to attach it to the FIN ?cutting out) edge of the dorsal fin or sanding (cutting out) leading
of theFIN in order to put the parts together??
Received: from RebelAir@aol.com
by imo21.mx.aol.com (IMOv18.1) id DPWIa07798
for <murphy-rebel@dcsol.com>; Mon, 1 Feb 1999 18:05:15 -0500 (EST)
Message-ID: <c9b76ba7.36b6332b@aol.com>
Date: Mon, 1 Feb 1999 18:05:15 EST
Mime-Version: 1.0
X-Mailer: AOL 3.0.i for Windows 95 sub 19
Hi There
As you know, the manual tells you explicity to offset the vertical fin left
or
right depending upon the rotation direction of the engine used. I think it
says 1/2" but is stated clearly. For those without installation
instructions,
the dorsal fin comes with quite good installation instructions re: rivet
spacing etc. actual pictures of installation steps. This area of
instructions
is well above average for the balance of the manual, so those without can
call
MAM for the paperwork. There are silent although on the question of fin
offset i.e. if you offset the fin per the manual, do you continue the offset
started or do you turn back straight up and down the fuselage. They should
be
clearer on this.
Brian #328R
Mime-Version: 1.0
Hi There
or
instructions,
instructions
call
be
clearer on this.
Brian #328R
SMTPSVC;
Mon, 1 Feb 1999 15:08:33 -0800
Date: Mon, 1 Feb 1999 15:10:35 -0800
Message-ID: <000301be4e38$16b5c960$14640a0a@tim-toshiba>
MIME-Version: 1.0
Importance: Normal
In-Reply-To: <199902012301.MAA16712@host02.net.voyager.co.nz>
Alister:
Did you apply any offset to the motor mount?
BTW, are you any where near Auckland? I have been know to be there
occasionally on my way to Melbourne.
Tim
Sent: Monday, February 01, 1999 3:02 PM
To: Murphy Rebel
perfect.
Alister
SMTPSVC;
MIME-Version: 1.0
Importance: Normal
Alister:
Tim
To: Murphy Rebel
perfect.
Alister
Curious....
Tim
To: Murphy Rebel
HTH .....bobp
by imo24.mx.aol.com (IMOv18.1) id 5YGOa03463
for <murphy-rebel@dcsol.com>; Mon, 1 Feb 1999 18:08:32 -0500 (EST)
Message-ID: <c8e3c6a8.36b633f0@aol.com>
Date: Mon, 1 Feb 1999 18:08:32 EST
Mime-Version: 1.0
By the way,,,
Installing the fin with or without offset makes no difference it all. The
whole installation steps for this job is easy whether or not there is an
offset. The only difference of note is what Alister mentioned of
countersinking 2 or 3 rivets if the there is an offset. In the scheme of
things, that is nothing.
Brian #328R
Mime-Version: 1.0
By the way,,,
Brian #328R
by imo11.mx.aol.com (IMOv18.1) id 1YCa004317
for <murphy-rebel@dcsol.com>; Mon, 1 Feb 1999 18:10:10 -0500 (EST)
Message-ID: <6b3ccc27.36b63452@aol.com>
Date: Mon, 1 Feb 1999 18:10:10 EST
Mime-Version: 1.0
Taking this argument further, having the fin neutral would also be only
effective at one speed only. Best to have it in the middle of whatever
setting is best. Whatever that is!!
Brian #328R
Mime-Version: 1.0
Brian #328R
Received: from dialup.voyager.co.nz (ts1p10.net.ashburton.voyager.co.nz
[203.21.25.174]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
NAA07597 for <murphy-rebel@dcsol.com>; Tue, 2 Feb 1999 13:23:58 +1300 (NZDT)
Message-Id: <199902020023.NAA07597@host02.net.voyager.co.nz>
Date: Tue, 2 Feb 1999 13:24:21 +1300
X-Priority: 3
MIME-Version: 1.0
Tim,
No, I applied no offset to the motor, and I ran the dorsal fin parallel to
the fuse from the front of the vertical fin.
I am afraid not, we live just south of ChristChurch in the South Island,
there is an International Airport there so it may be possible to route that
way.
Alister
X-Priority: 3
MIME-Version: 1.0
Tim,
way.
Alister
one,From: Tim Carter <tlcarter@email.msn.com>
To: 'Murphy Rebel' <murphy-rebel@dcsol.com>
Date: Tuesday, February 02, 1999 12:10 PM
Alister:
Tim
To: Murphy Rebel
whenits now sitting there with no bend in it at all, the set up is near to
perfect.
Alister
becausehe was building his Rebel. He decided NOT to offset the fin, because
Engineeringmuch !installing the fin with the offset was a pain in the attach bolt area.
4 " long, and about 2" wide, and is bent over about 1/4" - this is tooSome of the P-factor considerations are already handled in the
decision,at De Havilland a few years ago, and is currently building his own
FAR,and it seems to be satisfactory.
OPPOSITEand the possibility of changing to an engine that turned in the
aboutdirection, sometime later....
-muchoffsetting the vertical stab? It seems to me that a tab would almost
Do you know of any big engine Rebels (O-320) that have no offset? Howtab is required in terms of size?
Curious....
Tim
To: Murphy Rebel
takesseveral builders have NOT offset the vertical fin, either. (The offset
a-----------------------------orig.-------------------------------------care of adjustment, if required.)
HTH .....bobp
about
anattachedgeto Sanding (of the
Received: from nidlink.com (pm9-9.nidlink.com [216.18.141.64])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id RAA04710
for <murphy-rebel@dcsol.com>; Mon, 1 Feb 1999 17:28:06 -0800 (PST)
Message-ID: <36B65660.1A068EC8@nidlink.com>
Date: Mon, 01 Feb 1999 17:35:28 -0800
X-Mailer: Mozilla 4.5 [en] (Win95; I)
X-Accept-Language: en
MIME-Version: 1.0
References: <199902012301.MAA16712@host02.net.voyager.co.nz>
Content-Type: text/plain; charset=x-user-defined
Alister Yeoman wrote:
rudder
inputs with the Subaru installation. Originally I had the NSI which turned
wrong way and to correct I had to put a large trim tab. I redid the tail
put the recommended offset in and it is perfect.
Dave Bangle http://www.subielyc.com/
MIME-Version: 1.0
one,If I had to do mine again I would still leave the 3/4" offset in with the
I have an offset in mine as well and it is straight as an arrow with nowits now sitting there with no bend in it at all, the set up is near to
perfect.
Alister
rudder
Received: from the-benson-s (209-122-196-251.s251.tnt5.lnh.md.dialup.rcn.com
[209.122.196.251])
by smtp1.erols.com (8.8.8/8.8.5) with SMTP id XAA14293
for <murphy-rebel@dcsol.com>; Mon, 1 Feb 1999 23:03:52 -0500 (EST)
Message-ID: <004101be4e60$acd01ea0$fbc47ad1@the-benson-s>
Date: Mon, 1 Feb 1999 23:01:09 -0500
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.72.3155.0
Johannes:
I asked one of the MAM technical types about the offset for the O-320 and
was told not to bother, leave it straight. I was also told that several of
their pilots who have flown Rebels with and without dorsal fins could not
detect any differences in flying qualities between the two. It appears that
adding a dorsal fin may be more cosmetic than any thing else. Of course
with the O-320 we could probably use the extra weight in the aft end.
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Monday, February 01, 1999 3:05 PM
Hi !
[209.122.196.251])
MIME-Version: 1.0
X-Priority: 3
Johannes:
Hi !
Received: from the-benson-s (209-122-252-51.s305.tnt1.lnh.md.dialup.rcn.com
[209.122.252.51])
by smtp1.erols.com (8.8.8/8.8.5) with SMTP id OAA02157
for <murphy-rebel@dcsol.com>; Tue, 2 Feb 1999 14:11:03 -0500 (EST)
Message-ID: <00e701be4edf$52e893c0$fbc47ad1@the-benson-s>
Date: Tue, 2 Feb 1999 14:07:47 -0500
MIME-Version: 1.0
X-Priority: 3
It was the vertical stabilizer.
Date: Tuesday, February 02, 1999 1:02 PM
[209.122.252.51])
MIME-Version: 1.0
X-Priority: 3
thatLonnie:
Was that the dorsal fin they suggested leave straight, or is that actually
the vertical stab they suggested leave straight?
Tim
Sent: Monday, February 01, 1999 8:01 PM
To: Murphy Rebel
Johannes:
Sandingadding a dorsal fin may be more cosmetic than any thing else. Of course
Hi !
of(
Received: from [137.186.228.34] (helo=ms02-288.tor.istar.ca)
id 107rWI-0004nv-00; Tue, 2 Feb 1999 20:54:23 -0500
Mime-Version: 1.0
Message-Id: <E107rWI-0004nv-00@mail2.toronto.istar.net>
Date: Tue, 2 Feb 1999 20:54:23 -0500
FWIW - I believe the standard Murphy mounts include an offset, both
down, and to one side ..............
----------------------------------orig.------------------------------
Mime-Version: 1.0
Alister:
Tim
To: Murphy Rebel
perfect.
Alister
----------much !From: Bob Patterson <bob.patterson@canrem.com>
4 " long, and about 2" wide, and is bent over about 1/4" - this is toomuchSome of the P-factor considerations are already handled in the
Do you know of any big engine Rebels (O-320) that have no offset? Howantab is required in terms of size?
Curious....
Tim
To: Murphy Rebel
HTH .....bobp
At 08:53 PM 2/1/99 +0100, you wrote:attachedgeto Sanding (of the
