Page 1 of 2
Subaru powered cruise speeds
Posted: Fri Feb 17, 2012 10:59 pm
by Dick Kyro
Subject: Subaru powered cruise speeds
Date: Thu, 1 May 2003 18:43:52 -0400
Changed the subject line for you for future seaches!!! Wayne
Sent: Thursday, May 01, 2003 4:41 PM
Subject: Re: 0-235 Nu Chrome
Dick
What kind of airspeeds are you getting in cruise?
thanks
Dick Kyro wrote:
Not necessarily, the Sub is a stock 2.2 listed at 130 hp. It is
turning the prop thru a Ross 2.17/1 reduction drive, so my prop speed
is
relatively slow. I typically cruise at about 4600 rpm engine, which
gives me
a little over 2100 prop rpm.
Ken,
The Subaru is slow... 95MPH. It is also heavy. 1030# empty weight.
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
Dick
thanks
turning the prop thru a Ross 2.17/1 reduction drive, so my prop speed is
gives me
by paco
I had to speak up.
I'm surprised you are not getting higher cruise speeds with the 2.2.
I know we are talking about the 2.2 here, but for just for comparison sake,
I if run the EA-81 at 3700 rpm through a 2.2:1 reduction I am cruising at
around 85-90mph. I am a bit lighter at around 850-900# empty weight but the EA-
81 is probably only producing 60-70hp at this rpm and running effortlessly.
The other day it was smooth air and I was able to test higher power settings.
At 4400 engine rpm I was flying at a true 112mph. (GPS verified both
directions)I am now going to add some temporary fairings with some high speed
duct tape to see if adding fairings will gain me some more mph's.
More importantly, if you have made or are flying with homemade exhaust pipes,
make sure they do not allow any fumes into the cabin. I had a quick lesson on
CO poisoning at 4500 ft the other day. To be honest with you, it scared the
crap out me. I now put a swiss muffler on that exists behind the rear wheel
strut.
Frank
-> Ken,
-> The Subaru is slow... 95MPH. It is also heavy. 1030# empty weight.
-> _________________________________________________________________
-> MSN 8 with e-mail virus protection service: 2 months FREE*
-> http://join.msn.com/?page=features/virus
by paco
I have actually had people look at my plane/engine combo and tell me it would
never work let alone be a decent performer. One fellow stopped in to look at
it this winter and he told my hanger partner not to let me try to fly my Rebel
with this engine. He said I would never make it off the ground. My buddy told
him that I had 80+ flights on it this way at which time this person figured we
were all full of it.
I'm not sure why there is such a wide range of cruise speeds for Rebels of
similar build? I can even tell you that both my wings are built by two
different people and one needs quite a large trim tab on it just to keep the
wings level. (you might spot this in the pictures) This in addition to the
slight up elevator possition during cruise must eat away at even more
airspeed? I have heard of a couple O-320's and a few O-235's that cruise at
80mph? I don't understand? The other thing my Rebel seems to do that no one
else's does is glide!!! I have to fly my circuits so low just to keep the
speed under the 80mph flap limit. The slightest push on the stick and I'm at
95+ in the blink of an eye. I don't seem to have the severe sink rate that
people have talked about. I can throttle back to 3000rpm @ 60mph and fly
comfortably for an hour (I've done it many times) If I keep pulling on the
stick it just points to the sky and slows down to what seems to be not moving
at all! The angle on the airspeed pitot is so great that the needle shows 0.
Same thing when I asked the group about wheel pants. Some reported 3-5 mph
gains while others reported 7mph losses. I have come to believe that every
Rebel might have its own unique flying characteristics especially when it
comes to cruise speeds.
Maybe FWF weight is very critical in the Rebel, and maybe I was lucky enough
to get it right on.
Anyway, sorry about blabbing on. I use a 72", 3-Blade Warp, straight blades
set at 18.5 degrees. Now this is another issue that I have been involved with
on the Sub list. Some people don't seem to be able to turn their props
(exactly the same as mine) with the turbo EA-81. Maybe my carb'd EA-81 is
putting out more than 90hp?, I don't know?
Regular spring gear, no pants.
Anyway If there are any dis-believers I will have to post some MPEGS on my
site this spring or you will have to fly to Sarnia some day.
Frank
-> Hi Frank,
-> Those numbers look good indeed for an EA-81. Could I ask what prop you're
-> using? Do you have the spring gear or bungee? Do you have wheel pants?
-> Thanks much!
-> Joel Jacobs
-> From: <paco@dcsol.com>
-> Sent: Friday, May 02, 2003 9:45 AM
-> Subject: Re: Subaru powered cruise speeds
-> > I had to speak up.
-> > I'm surprised you are not getting higher cruise speeds with the 2.2.
-> > I know we are talking about the 2.2 here, but for just for comparison
-> sake,
-> > I if run the EA-81 at 3700 rpm through a 2.2:1 reduction I am cruising at
-> > around 85-90mph. I am a bit lighter at around 850-900# empty weight but
-> the EA-
-> > 81 is probably only producing 60-70hp at this rpm and running
-> effortlessly.
-> > The other day it was smooth air and I was able to test higher power
-> settings.
-> > At 4400 engine rpm I was flying at a true 112mph. (GPS verified both
-> > directions)I am now going to add some temporary fairings with some high
-> speed
-> > duct tape to see if adding fairings will gain me some more mph's.
-> > More importantly, if you have made or are flying with homemade exhaust
-> pipes,
-> > make sure they do not allow any fumes into the cabin. I had a quick lesson
-> on
-> > CO poisoning at 4500 ft the other day. To be honest with you, it scared
-> the
-> > crap out me. I now put a swiss muffler on that exists behind the rear
-> wheel
-> > strut.
-> > Frank
-> > -> Ken,
-> > -> The Subaru is slow... 95MPH. It is also heavy. 1030# empty weight.
-> > -> _________________________________________________________________
-> > -> MSN 8 with e-mail virus protection service: 2 months FREE*
-> > -> http://join.msn.com/?page=features/virus
-> > To unsubscribe from this list go to:
-> > http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
by paco
Where are you located Dick?
On 5/2/2003 10:08 AM, DKY33@HOTMAIL.COM wrote to MURPHY-REBEL:
-> From <dky33@hotmail.com> Fri, 02 May 2003 06:49:40 -0800 remote from
dcsol.com
-> Received: by dcsol.com (Wildcat! SMTP Router v5.6.450.61)
-> for murphy-rebel@dcsol.com; Fri, 02 May 2003 06:49:40 -0800
-> Received: from f73.law14.hotmail.com ([64.4.21.73]) EHLO=hotmail.com
-> by dcsol.com (Wildcat! SMTP v5.6.450.61) with SMTP
-> id 246920312; Fri, 02 May 2003 06:49:39 -0800
-> Received: from mail pickup service by hotmail.com with Microsoft SMTPSVC;
-> Fri, 2 May 2003 07:49:58 -0700
-> Received: from 12.4.27.248 by lw14fd.law14.hotmail.msn.com with HTTP;
-> Fri, 02 May 2003 14:49:57 GMT
-> X-Originating-IP: [12.4.27.248]
-> X-Originating-Email: [dky33@hotmail.com]
-> From: "Dick Kyro" <dky33@hotmail.com>
-> To: murphy-rebel@dcsol.com
-> Bcc:
-> Date: Fri, 02 May 2003 09:49:57 -0500
-> X-Orig-Mime-Version: 1.0
-> X-Orig-Content-Type: text/plain; format=flowed
-> Message-ID: <Law14-F73rWjAKYVpMm0000afdd@hotmail.com>
-> X-OriginalArrivalTime: 02 May 2003 14:49:58.0295 (UTC) FILETIME=
[1A043270:01C310BA]
-> Hi Frank,
-> The discussion of cruise speeds has always haunted me. I built an Avid
Flyer
-> STOL wing the factory said it would cruise at 95 mph with a 582.
-> That airplane would NEVER see those kinds of speeds with that engine.
-> At any rate, My Rebel is what it is. I checked it with a GPS flying
-> 4 directions. I have fat 800 tires, and bungies.
-> you certainly are getting great performance with the EA81. MAM shows an 80
-> MPH cruise with the 912, 105/w0235, and 120 with the 0320.
-> I am thinking about going to a lighter engine to improve my HP/weight
-> ratio. The Subaru is a helluva engine, but heavy.
-> Dick
-> >From: paco@dcsol.com
-> >Reply-To: <murphy-rebel@dcsol.com>
-> >To: murphy-rebel@dcsol.com
-> >Subject: Re: Subaru powered cruise speeds
-> >Date: Fri, 02 May 2003 05:45:57 -0800
-> >I had to speak up.
-> >I'm surprised you are not getting higher cruise speeds with the 2.2.
-> >sake,
-> >I if run the EA-81 at 3700 rpm through a 2.2:1 reduction I am cruising at
-> >around 85-90mph. I am a bit lighter at around 850-900# empty weight but
-> >EA-
-> >81 is probably only producing 60-70hp at this rpm and running effortlessly.
-> >The other day it was smooth air and I was able to test higher power
-> >settings.
-> >At 4400 engine rpm I was flying at a true 112mph. (GPS verified both
-> >directions)I am now going to add some temporary fairings with some high
-> >speed
-> >duct tape to see if adding fairings will gain me some more mph's.
-> >More importantly, if you have made or are flying with homemade exhaust
-> >pipes,
-> >make sure they do not allow any fumes into the cabin. I had a quick lesson
-> >on
-> >CO poisoning at 4500 ft the other day. To be honest with you, it scared the
-> >crap out me. I now put a swiss muffler on that exists behind the rear wheel
-> >strut.
-> >Frank
-> >-> Ken,
-> >-> The Subaru is slow... 95MPH. It is also heavy. 1030# empty weight.
-> >-> _________________________________________________________________
-> >-> MSN 8 with e-mail virus protection service: 2 months FREE*
-> >-> http://join.msn.com/?page=features/virus
-> STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
-> http://join.msn.com/?page=features/junkmail
by Dick Kyro
Hi Frank,
The discussion of cruise speeds has always haunted me. I built an Avid Flyer
Dick
I had to speak up.
sake,
EA-
settings.
speed
pipes,
on
strut.
Frank
-> Ken,
by Joel Jacobs
Hi Frank,
Thanks much!
Joel Jacobs
I had to speak up.
sake,
the EA-
effortlessly.
settings.
speed
pipes,
on
wheel
strut.
Frank
-> Ken,
by Dick Kyro
Fort Wayne, In.
Date: Fri, 02 May 2003 10:09:28 -0800
dcsol.com
SMTPSVC;
-> Bcc:
[1A043270:01C310BA]
-> Hi Frank,
Flyer
80
-> Dick
comparison
-> >sake,
at
-> >EA-
effortlessly.
-> >settings.
-> >speed
-> >pipes,
lesson
-> >on
wheel
-> >strut.
-> >Frank
-> >-> Ken,
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
by Walter Klatt
Hi, Frank. Very interesting to hear about your great
performance out of that EA81. I would bet that 72" WD
has a lot to do with that. <g>
I do have a question about your c of g, though. I have
one of those Rebels with the high sink rate at 60 mph.
My c of g is at 9.7 which is a little nose heavy and am
wondering if that is doing it. Mine is also a little
heavy right now with the 0320 and amphibs, but I
remember that even back on wheels, it still had that
high sink rate at 60 with power off. So would be
interested in hearing your what c of g is.
paco@dcsol.com
Sent: Friday, May 02, 2003 11:07 AM
to get it right on.
Sarnia some day.
Frank
-> Hi Frank,
-> Thanks much!
-> Joel Jacobs
-> sake,
-> the EA-
-> effortlessly.
-> settings.
-> speed
-> pipes,
-> on
-> the
-> wheel
-> > strut.
-> > Frank
-> > -> Ken,
cribe.wcx
Archives located at
by Dick Kyro
Hi Bob,
My bungies do have fairings over them. That's why I am so depressed!!
Dick
Date: Fri, 02 May 2003 15:29:54 -0400
Hi Dick !
You're not doing so badly - I flew a similarly configured
Rebel, and saw about 110 mph at about 4,800 rpm - stock Legacy 2.2,
Ross Redrive, W-D prop...... and about 1,100 fpm climb.
My old O-235 powered Rebel never cruised much over 95 mph,
although I have flown 118 hp. O-235-L2C's that would give 110 easy .
One thought - if you have the standard gear, if you add
streamlined fairings to the legs, & inner (bungee) tubes, you can
pick up another 10 mph !! Steve Sloan has done a TERRIFIC job
of streamlining EVERYTHING on his Rebel, including the tailwheel,
and is getting at least 25 mph more cruise than most !!! There
are some photos of his 'Rebelee de Bebe' in the archives ....
PS
I agree that a lighter engine will really help performance.
I still believe that a 100 hp Rotax 912-S would make a GREAT Rebel -
and one day, I might just try that combo on 1500 Amphibs !! ;-)
----------------------------------orig.-----------------------------
At 09:49 AM 5/2/03 -0500, you wrote:
Hi Frank,
Flyer
80
Dick
I had to speak up.
comparison
sake,
at
EA-
effortlessly.
settings.
speed
pipes,
lesson
on
wheel
strut.
Frank
-> Ken,
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
by Dick Kyro
Hello again,
Would you know by chance what this person with the 2.2 had for a static RPM
with the Ross?? I am assuming he has the same drive and ratio as me. I do
not know what my pitch is, I set the prop at 4800 static.
I do know if I do not pull the nose up on take off, my rpm's go to over 5k
very quickly, so I pull back on the power. Perhaps I have it pitched too
fine.
Dick
Hi Dick !
PS
Hi Frank,
Flyer
80
Dick
I had to speak up.
comparison
sake,
at
EA-
effortlessly.
settings.
speed
pipes,
lesson
on
wheel
strut.
Frank
-> Ken,
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
by Bob Patterson
Hi Dick !
PS
Hi Frank,
Dick
I had to speak up.
sake,
EA-
settings.
speed
pipes,
on
strut.
Frank
-> Ken,
by paco
Walter,
I agree, I think I use that 72" WD prop like a helicopter uses the main
rotor.
If my memory serves me correct, I am only turning the prop at 1600-1700 rpm.
Now the CofG might be the reason for the lack of sink rate. When I matched the
EA-81 up to the firewall, I built the mount so the engine was a far back as I
could put it but still allow me to service the oil filter and belt. I then had
a 4 inch extension added to the gearbox so the prop would be where the 912
cowl needed it to be. I think I just lucked out.
My CofG with just me and 15 gals of fuel (which is like 5 hrs of flying) is
12.66. Add a passenger and it's 13.02
I always felt that I was a little nose heavy because I can't get the tail
wheel to touch first on landing if I tried. Even with full elevator which I
adjusted to give me more than the recommended up travel, the tail is about 4
inches of the ground at touch down.
Frank
On 5/3/2003 2:29 PM, WALTER.KLATT@SHAW.CA wrote to MURPHY-REBEL:
-> From <walter.klatt@shaw.ca> Fri, 02 May 2003 16:24:53 -0800 remote from
dcsol.com
-> for murphy-rebel@dcsol.com; Fri, 02 May 2003 16:24:53 -0800
-> Received: from shawidc-mo1.cg.shawcable.net ([24.71.223.10])
EHLO=pd5mo3so.prod.shaw.ca
-> id 8443953; Fri, 02 May 2003 16:24:52 -0800
-> Received: from pd2mr4so.prod.shaw.ca (pd2mr4so-ser.prod.shaw.ca
[10.0.141.107])
-> by l-daemon (iPlanet Messaging Server 5.2 HotFix 1.14 (built Mar 18 2003))
-> with ESMTP id <0HEA007GTBRASX@l-daemon> for murphy-rebel@dcsol.com; Fri,
-> 02 May 2003 18:23:34 -0600 (MDT)
-> Received: from pn2ml10so.prod.shaw.ca
-> (pn2ml10so-qfe0.prod.shaw.ca [10.0.121.80])
-> with ESMTP id <0HEA004R0BRAJ5@l-daemon> for murphy-rebel@dcsol.com; Fri,
-> Received: from user ([24.82.18.134])
-> by l-daemon (iPlanet Messaging Server 5.1 HotFix 0.8 (built May 12 2002))
-> with SMTP id <0HEA00A9MBR9M8@l-daemon> for murphy-rebel@dcsol.com; Fri,
-> Date: Fri, 02 May 2003 17:24:19 -0700
-> From: Walter Klatt <walter.klatt@shaw.ca>
-> Subject: RE: Subaru powered cruise speeds
-> In-reply-to: <1051898820@dcsol.com>
-> Message-id: <PFEOJDIIGOHLFACHDMDNMEEACHAA.Walter.Klatt@shaw.ca>
-> X-Orig-MIME-version: 1.0
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1165
-> X-Mailer: Microsoft Outlook IMO, Build 9.0.2416 (9.0.2911.0)
-> X-Orig-Content-type: text/plain; charset=iso-8859-1
-> X-Orig-Content-transfer-encoding: 7BIT
-> Importance: Normal
-> X-Priority: 3 (Normal)
-> X-MSMail-priority: Normal
-> Hi, Frank. Very interesting to hear about your great
-> performance out of that EA81. I would bet that 72" WD
-> has a lot to do with that. <g>
-> I do have a question about your c of g, though. I have
-> one of those Rebels with the high sink rate at 60 mph.
-> My c of g is at 9.7 which is a little nose heavy and am
-> wondering if that is doing it. Mine is also a little
-> heavy right now with the 0320 and amphibs, but I
-> remember that even back on wheels, it still had that
-> high sink rate at 60 with power off. So would be
-> interested in hearing your what c of g is.
-> Walter
-> > From: mike.davis@dcsol.com
-> > [mailto:mike.davis@dcsol.com]On Behalf Of
-> > paco@dcsol.com
-> > Sent: Friday, May 02, 2003 11:07 AM
-> > To: murphy-rebel@dcsol.com
-> > Subject: Re: Subaru powered cruise speeds
-> > I have actually had people look at my
-> > plane/engine combo and tell me it would
-> > never work let alone be a decent performer.
-> > One fellow stopped in to look at
-> > it this winter and he told my hanger partner
-> > not to let me try to fly my Rebel
-> > with this engine. He said I would never make
-> > it off the ground. My buddy told
-> > him that I had 80+ flights on it this way at
-> > which time this person figured we
-> > were all full of it.
-> > I'm not sure why there is such a wide range
-> > of cruise speeds for Rebels of
-> > similar build? I can even tell you that both
-> > my wings are built by two
-> > different people and one needs quite a large
-> > trim tab on it just to keep the
-> > wings level. (you might spot this in the
-> > pictures) This in addition to the
-> > slight up elevator possition during cruise
-> > must eat away at even more
-> > airspeed? I have heard of a couple O-320's
-> > and a few O-235's that cruise at
-> > 80mph? I don't understand? The other thing
-> > my Rebel seems to do that no one
-> > else's does is glide!!! I have to fly my
-> > circuits so low just to keep the
-> > speed under the 80mph flap limit. The
-> > slightest push on the stick and I'm at
-> > 95+ in the blink of an eye. I don't seem to
-> > have the severe sink rate that
-> > people have talked about. I can throttle
-> > back to 3000rpm @ 60mph and fly
-> > comfortably for an hour (I've done it many
-> > times) If I keep pulling on the
-> > stick it just points to the sky and slows
-> > down to what seems to be not moving
-> > at all! The angle on the airspeed pitot is
-> > so great that the needle shows 0.
-> > Same thing when I asked the group about
-> > wheel pants. Some reported 3-5 mph
-> > gains while others reported 7mph losses. I
-> > have come to believe that every
-> > Rebel might have its own unique flying
-> > characteristics especially when it
-> > comes to cruise speeds.
-> > Maybe FWF weight is very critical in the
-> > Rebel, and maybe I was lucky enough
-> > to get it right on.
-> > Anyway, sorry about blabbing on. I use a
-> > 72", 3-Blade Warp, straight blades
-> > set at 18.5 degrees. Now this is another
-> > issue that I have been involved with
-> > on the Sub list. Some people don't seem to
-> > be able to turn their props
-> > (exactly the same as mine) with the turbo
-> > EA-81. Maybe my carb'd EA-81 is
-> > putting out more than 90hp?, I don't know?
-> > Regular spring gear, no pants.
-> > Anyway If there are any dis-believers I will
-> > have to post some MPEGS on my
-> > site this spring or you will have to fly to
-> > Sarnia some day.
-> > Frank
-> > -> Hi Frank,
-> > -> Those numbers look good indeed for an
-> > EA-81. Could I ask what prop you're
-> > -> using? Do you have the spring gear or
-> > bungee? Do you have wheel pants?
-> > -> Thanks much!
-> > -> Joel Jacobs
-> > -> ----- Original Message -----
-> > -> From: <paco@dcsol.com>
-> > -> To: <murphy-rebel@dcsol.com>
-> > -> Sent: Friday, May 02, 2003 9:45 AM
-> > -> Subject: Re: Subaru powered cruise speeds
-> > -> > I had to speak up.
-> > -> > I'm surprised you are not getting
-> > higher cruise speeds with the 2.2.
-> > -> > I know we are talking about the 2.2
-> > here, but for just for comparison
-> > -> sake,
-> > -> > I if run the EA-81 at 3700 rpm through
-> > a 2.2:1 reduction I am cruising at
-> > -> > around 85-90mph. I am a bit lighter at
-> > around 850-900# empty weight but
-> > -> the EA-
-> > -> > 81 is probably only producing 60-70hp
-> > at this rpm and running
-> > -> effortlessly.
-> > -> > The other day it was smooth air and I
-> > was able to test higher power
-> > -> settings.
-> > -> > At 4400 engine rpm I was flying at a
-> > true 112mph. (GPS verified both
-> > -> > directions)I am now going to add some
-> > temporary fairings with some high
-> > -> speed
-> > -> > duct tape to see if adding fairings
-> > will gain me some more mph's.
-> > -> > More importantly, if you have made or
-> > are flying with homemade exhaust
-> > -> pipes,
-> > -> > make sure they do not allow any fumes
-> > into the cabin. I had a quick lesson
-> > -> on
-> > -> > CO poisoning at 4500 ft the other day.
-> > To be honest with you, it scared
-> > -> the
-> > -> > crap out me. I now put a swiss muffler
-> > on that exists behind the rear
-> > -> wheel
-> > -> > strut.
-> > -> > Frank
-> > -> > -> Ken,
-> > -> > -> The Subaru is slow... 95MPH. It is
-> > also heavy. 1030# empty weight.
-> > _____________________________________________
-> > -> > -> MSN 8 with e-mail virus protection
-> > service: 2 months FREE*
-> > -> > -> http://join.msn.com/?page=features/virus
-> > -> > To unsubscribe from this list go to:
-> cribe.wcx
-> -> > Archives located at
-> http://rebel:builder@www.dcsol.com:81/default.htm
-> -> > To contact the list admin, e-mail
-> mike.davis@dcsol.com
-> To unsubscribe from this list go to:
-> http://www.dcsol.com:81/public/code/html-subscribe.wcx
-> Archives located at
-> To contact the list admin, e-mail mike.davis@dcsol.com
by Walter Klatt
My flying c o g is between 12 and 13 normally as well,
so I don't think that is it. Your low sink rate at 60
then is more likely just due to your lower weight. Mine
used to glide pretty good at 70 or 80, too, back when I
was on wheels. But if I needed to drop a little
altitude on final, all I had to do was slow it down
more, instead of slipping. This was with full flaps on
final.
As for getting that tail wheel down, I do believe a
nose heavy plane does make it more challenging, and I
had that problem, too.
Sounds like you have a good combo there with that
Subaru. Enjoy.
paco@dcsol.com
Sent: Saturday, May 03, 2003 3:54 PM
Walter,
rotor.
Frank
dcsol.com
Router v5.6.450.61)
-> Received: from
16:24:52 -0800
[10.0.141.107])
-> Message-id:
V6.00.2800.1165
charset=iso-8859-1
your great
that 72" WD
though. I have
rate at 60 mph.
nose heavy and am
also a little
still had that
-> Walter
-> > paco@dcsol.com
-> > Frank
-> > -> Hi Frank,
-> > -> Joel Jacobs
-> > -> sake,
-> > -> the EA-
-> > -> settings.
-> > -> speed
-> > -> pipes,
-> > -> on
-> > -> the
-> > -> wheel
-> > -> > strut.
-> > -> > Frank
-> > -> > -> Ken,
-> cribe.wcx
cribe.wcx
Archives located at
by Rebflyer
Hi Dick, I hope you're not fighting the Smith field thing in Ft. Wayne. I've
family on the north side off Dupont Rd. Curt N97MR
