AULA for salw
sub
AULA for salw
Post by sub » Fri Feb 17, 2012 10:56 pm
Bob P. and other members,
I've pretty well decided I want to move up to a full gross Rebel and
first need to sell mine:
Here are the specs and more info. on request, as well as pics.
AULA
Factory built in 1993, sat over two years by original owner until I
purchased in Aug/98
912 completly overhauled 2 years ago, under 200 hours and after market
high compression pistons since added
3 props, one 2 blade 68" GSC wooden, one 3-blade Warp drice ground
adjustable, One new Ivoprop 3-blade in-flight adjustable
-straight floats, 1300 or so, tight with minor wrinkles
-Aero skis 2000, new lexan bottoms
-standard wheel gear and brakes, new turf tires, never used, new set of
bungie rings 9044's, 12 in all, 8 currently installed
-new protable radio and two head sets
-wing covers, elevator covers and cowl cover (Aero Covers)
-basic instrument panel
-Some minor work required on cowling after testing larger air outlet and
some minor panel work
Flies great as is, needs agood home.
Price, all inclusive $45,000 and firm. Price negotiable up to $50,000 if
buyer wants all work down.
Please pass word on to freinds who want a great flying machine. As Bob
P. has often said, you find a cheaper machine to operate, fuel
consumption 3-4 gallons/hour, only need your Ultralight permit etc.
Maintenance of 912 is minimal and owner does not require annuals and
work can be done yourself.
Thansk for any leads.
Aurele
063R
705-372-5248 or e-mail reply
P.S. Curently installing airbox complete with carb heat, also have a new
S.S. muffler and piping for new exhaust.
