Just to be sure, from reading the manual it appears that with the stick
centered and the flaps all the way up the flaps and ailerons should be
aligned with each other, both reflexed up 5 degrees. Right? When I set
mine up this way the upper surface of the flaps were perfectly in line with
the cabin top which was great because the upper skin of the little flap
spacer box to fair in the flap to fuselage gap extended over the flap and
laid right on top of it with the flaps all the way up. And the lower
surface of the aileron spade was exactly in line with the lower surface of
the wing.
SR #044
Flap/Aileron setup
Flap/Aileron setup
Perfect, Mike !! Sounds like you're going to have a very
nice flying Moose !!! :-)
-------------------------------orig.-----------------------------------
the wing.
SR #044
