flap cable routing
Posted: Sat Feb 18, 2012 1:46 am
by Rhodes
Jim
I have mine going right through the center of the bellcrank(above or below
the pivot point) and just fitting it now. Ron Kakeldey already did his this
way. I have a fast build and I would say just go ahead and rivet the bell
crank in place - it is already installed on the FB. My cables all go through
the bulkheads to allow for a cabin floor level extended baggage area. Have
also added several pulleys as Murphy uses plastic guides to change angles as
much as 8 degrees. I believe a rule of thumb is 3 degrees but modern
nylon/uhmw guides will likely last forever at larger angles.
Steve Rhodes
Sent: Saturday, February 22, 2003 05:13
Subject: flap cable routing
Curse Murphy and their manuals.....but I sure do like this project. I'm
working on the fuselage floor frame of a Super Rebel (179). There are
holes
for the rudder cables and elevator push rod through carrythroughs 4 thru
8.
The bell crank for the elevator push rod will soon be on the center of 8.
Where will the flap cable be routed? I am afraid to start riveting until I
know.
Jim SR 179
flap cable routing
by goody
working on the fuselage floor frame of a Super Rebel (179). There are holes
for the rudder cables and elevator push rod through carrythroughs 4 thru 8.
know.
Jim SR 179
flap cable routing
by Don Boardman
Jim,
Check out the pictures under super rebel fuselage on Maddog.
I posted a few (not all grouped together) showing our approach to allowing
an extended baggage floor. It shows the particulars of moving the flap cable
routing to the back of the fuselage.
Don Boardman
& Partner, Randy Bowers
Super Moose #130 M-14PF 400HP, MT-prop, Aerocet 3500 amphibs, Rome, NY
