Elec flaps
Elec flaps
Post by Mike Davis » Fri Feb 17, 2012 4:52 pm
Received: from Luscomb806@aol.com
by imo17.mx.aol.com (IMOv18.1) id IKAAa03210
for <murphy-rebel@dcsol.com>; Thu, 31 Dec 1998 21:38:06 +1900 (EST)
Message-ID: <ab679b50.368c350e@aol.com>
Date: Thu, 31 Dec 1998 21:38:06 EST
Mime-Version: 1.0
Subject: Elec flaps
X-Mailer: AOL 4.0 for Windows 95 sub 226
Al, /first i bought a Lnear actuator, 500 lb torc with a 3 inch stroke ,
speed
10 seconds actuation time . I used two 1 1/2 angles on the right side floor
between the door post and the small window . ( it might helpto leave about 1
inch more room when cutting out the window) I didnt know I was going to use
elec flaps when i cut my window.I ran a 29 1/2 push rod up behind the door
post to a 6'' bellcrank. I beefed up the area on the wall in the area of the
bellcrank with 1/4 inch plate al witch I tied to the two bulk heads . Where
the horn from the flap assembly comes down I welded a 5" horn to the rear
cut off the one that comes down. Thats 5" from the pivot point to the rear.
tied that horn to the other end of the bellcrank with a 3" push rod. With
assembly together I get 37 degrees of flap. Thats about it in a nut shell.
Les vincent SR24
Elec flaps
Received: from sps1 (1Cust86.tnt14.krk1.da.uu.net [208.253.25.86])
by smtp2.mailsrvcs.net with ESMTP id WAA13678
for <murphy-rebel@dcsol.com>; Mon, 4 Jan 1999 22:15:06 -0600 (CST)
Message-Id: <199901050415.WAA13678@smtp2.mailsrvcs.net>
Reply-To: <paxhia@gte.net>
Subject: Re: Elec flaps
Date: Mon, 4 Jan 1999 20:17:58 -0800
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1161
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Les, thanks for the info on your flap system. Does the actuator stop
automatically or does it free wheel when it gets to the end of the stroke
(like the older Cessna flaps)? Al Paxhia SR026
Subject: Elec flaps
Date: Thursday, December 31, 1998 6:38 PM
speed
floor
about 1
use
door
Where
rear and
rear. I
With the
shell.
Les vincent SR24
Elec flaps
by imo26.mx.aol.com (IMOv18.1) id NKDa000811
for <murphy-rebel@dcsol.com>; Tue, 5 Jan 1999 16:23:15 -0500 (EST)
Message-ID: <f65d3e30.369282c3@aol.com>
Date: Tue, 5 Jan 1999 16:23:15 EST
Mime-Version: 1.0
Al, the actuator free wheels at the end of the stroke. In my driveway it
works
real good. I dont see any reason it wont work as good in actual use. I
shoud
know for sure in a month or twoI,m waiting for my engine mount from Murphy
now. Also my cowling.
Les "Vincent SR24
