A couple of Elite questions
Posted: Fri Feb 17, 2012 10:43 pm
I have recently started building an Elite, and have run into a couple of
areas where the instructions don't seem very helpful (well, more than a
couple, but I've gotten answers for the others).
1) The instructions tell you to put the fuel filler on the inside of the
top skin. The 2 1/4" hole isn't big enough to accommodate the filler.
Presumably they mean the outside? And in the venting instuctions, I see
a reference to flush filler caps. Are these available?
2) When trying to rig the aileron torque tube, I seem to have about 5
deg. too much up, and too little down, using the specified pushrod
length of 7 5/8". I don't actually have the aileron finished, but have
jury rigged the horn on a hinge bracket. Even with the adjustment all
the way in the short direction (which shortens it by about 1/8"), I
still don't get the specified travel. I also notice that the horn comes
up against the forward end of the slot in the lower skin, but comes
nowhere near the rear end of said slot.
Any ideas?
Any ideas?
