Elevator ;Rudder TIPS
Received: from fwd06.btx.dtag.de (fwd06.btx.dtag.de [194.25.2.166])
by mailout08.btx.dtag.de with smtp
id 0ztc7c-0003pt-00; Fri, 25 Dec 1998 19:38:00 +0100
Received: (068612707-0001(btxid)@[193.159.8.188])
by fwd06.btx.dtag.de
id <m0ztc7Q-0003CZC>; Fri, 25 Dec 1998 19:37:48 +0100
Message-Id: <m0ztc7Q-0003CZC@fwd06.btx.dtag.de>
Date: Fri, 25 Dec 1998 19:37:48 +0100
Subject: Elevator ;Rudder TIPS
X-Mailer: T-Online eMail 2.2
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8BIT
X-Sender: 068612707-0001@t-online.de
From: Johannes.Laubenthal@t-online.de (Johannes Laubenthal)
Merry Christmas!
Want to install my tips removable. Rivnuts or Nutserts for example.Does
anyone
tried this? Rivetsize and material( Aluminium or Stainless)??
Johannes Laubenthal Germany R 603
MIME-Version: 1.0
Merry Christmas!
anyone
Received: from nidlink.com (pm5-31.nidlink.com [206.96.73.38])
by enaila.nidlink.com (8.8.5/8.8.5) with ESMTP id KAA12393
for <murphy-rebel@dcsol.com>; Fri, 25 Dec 1998 10:55:19 -0800 (PST)
Message-ID: <3683E135.B32D551D@nidlink.com>
Date: Fri, 25 Dec 1998 11:02:13 -0800
X-Mailer: Mozilla 4.5 [en] (Win95; I)
X-Accept-Language: en
MIME-Version: 1.0
Subject: Re: Elevator ;Rudder TIPS
References: <m0ztc7Q-0003CZC@fwd06.btx.dtag.de>
Content-Type: text/plain; charset=x-user-defined
I used rivnuts, aluminum with stainless tread inserts. Install like pop
rivets.
Screw size 6-32. Also used these for all my inspection covers, fairing
covers and
everything else that needed removal. Would use nut plates if had to do over
again. More timeconsuming to install but they would never spin.
Dave Bangle
MIME-Version: 1.0
rivets.
covers and
Dave Bangle
anyoneMerry Christmas!
Received: from [137.186.225.31] (helo=ms01-285.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zuI0t-0000kb-00; Sun, 27 Dec 1998 10:21:51 -0500
Mime-Version: 1.0
Message-Id: <E0zuI0t-0000kb-00@mail2.toronto.istar.net>
Date: Sun, 27 Dec 1998 10:21:51 -0500
Have tried Rivnuts - generally NOT a good idea! They almost always
start to slip & spin - pretty useless !! I believe the larger diameter
rivnuts would be better, especially if they were installed with epoxy or
ProSeal. They work better because, having larger diameter, there is more
surface area to grip, therefor less likely to slip....
Floating nutplates are ideal, but a LOT of work to install.
For what it's worth, the Murphy factory always rivets the tips on -
they are so good at drilling out rivets, they claim it's just as fast as
undoing bolts !!!
-------------------------orig.------------------------------------
Mime-Version: 1.0
undoing bolts !!!
Received: from RebelAir@aol.com
by imo27.mx.aol.com (IMOv18.1) id EAFAa01706
for <murphy-rebel@dcsol.com>; Sun, 27 Dec 1998 14:36:51 -0500 (EST)
Message-ID: <aa840fcb.36868c53@aol.com>
Date: Sun, 27 Dec 1998 14:36:51 EST
Mime-Version: 1.0
X-Mailer: AOL 3.0.i for Windows 95 sub 19
Hi
I agree with Dave Bangle. Nut plates are more work to put it but then you
never have to worry about them spinning. Al rivnuts can either spin or get
stripped. If you replace the rivnuts you have a large hole left to deal
with
as well.
Brian
Mime-Version: 1.0
Hi
with
as well.
Brian
by imo21.mx.aol.com (IMOv18.1) id EWVJa24870
for <murphy-rebel@dcsol.com>; Sun, 27 Dec 1998 14:48:57 -0500 (EST)
Message-ID: <63f412ab.36868f29@aol.com>
Date: Sun, 27 Dec 1998 14:48:57 EST
Mime-Version: 1.0
Hi
I believe that is a 'stretch' for the Murphy folks to say that it is just as
fast to drill out 2 rivets than to unscrew one 6-32 by 3/8" screw. Give me
reversible drill unscrewing screws vs. drilling out 2 rivets and you will
lose
everytime. The main factor is that you assume you can drill out all of
those
holes with NO damage to the main skins etc. Why bother taking the risk?
Brian #328R
Mime-Version: 1.0
Hi
lose
those
Brian #328R
Received: from dialup.voyager.co.nz (ts1p06.net.ashburton.voyager.co.nz
[203.21.25.170]) by host02.net.voyager.co.nz (8.8.8/8.6.12) with ESMTP id
LAA09538 for <murphy-rebel@dcsol.com>; Mon, 28 Dec 1998 11:30:55 +1300
(NZDT)
Message-Id: <199812272230.LAA09538@host02.net.voyager.co.nz>
Date: Mon, 28 Dec 1998 11:31:15 +1300
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1155
MIME-Version: 1.0
Hi there,
I'll just put my two cents worth in here, after building and painting, I
had to remove both my elevator tip and wing tip for the odd mod or two, I
found it was absolutely no problem even though I had riveted them on.
They were off in just a few minutes, the rivets are dead cheap to replace
and they are light! (remember after building an aircraft we have all the
skills now!!!)
The only downside was that they need to be repainted, but what I did there
was I purchased an ink pen approximately the same color as the paintwork
then a few minutes latter you would not know the difference.
Alister
(NZDT)
X-Priority: 3
MIME-Version: 1.0
Hi there,
skills now!!!)
Alister
asFrom: RebelAir@aol.com
Date: Monday, December 28, 1998 8:48 AM
Hi
me afast to drill out 2 rivets than to unscrew one 6-32 by 3/8" screw. Give
losereversible drill unscrewing screws vs. drilling out 2 rivets and you will
thoseeverytime. The main factor is that you assume you can drill out all of
Brian #328R
Received: from Rebflyer@aol.com
by imo23.mx.aol.com (IMOv18.1) id 8GCMa07017
for <murphy-rebel@dcsol.com>; Thu, 31 Dec 1998 16:27:06 -0500 (EST)
Message-ID: <4211bb16.368bec2a@aol.com>
Date: Thu, 31 Dec 1998 16:27:06 EST
Mime-Version: 1.0
X-Mailer: AOL 4.0 for Windows 95 sub 214
Hi Johannes, Curt Martin.
I installed my tips with floating nut plates. That's wing, rudder, and
elevator. I then used a structural screw ( looks like it already has a
washer
under it) and a thin plastic washer under the head to protect the glass.
Works great, making inspections much easier. I did widen out the spacing
slightly more than the rivets called for, but you'll find the spacing is
pretty natural.
Keep at it, it's really worth it. Curt N97MR
Mime-Version: 1.0
washer
pretty natural.
Received: from ocer.netexp.net (unverified [205.182.69.164]) by
merlin.netexp.net
(Rockliffe SMTPRA 2.1.4) with SMTP id <B0004947875@merlin.netexp.net> for
Fri, 01 Jan 1999 14:01:36 -0500
Message-ID: <008e01be35bb$a719e080$0100a8c0@ocer.netexp.net>
Date: Fri, 1 Jan 1999 14:19:22 -0500
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Sunday, December 27, 1998 10:10 AM
they seem far superior to the rivnuts - they have teeth under the head that
digs into the sheet metal you are installing them in. Even in thin sheet
metal, they are very secure. I can't imagine them coming lose and spinning.
They have a special tool to install them with, but the rivnut installation
tool works great.
Joel
merlin.netexp.net
MIME-Version: 1.0
X-Priority: 3
Wicks sells a type they call 'NutSerts'. I've used them a few times andHave tried Rivnuts - generally NOT a good idea! They almost always
tool works great.
Joel
Received: from [137.186.224.18] (helo=ms01-18.tor.istar.ca)
id 0zweKj-00079X-00; Sat, 2 Jan 1999 22:36:05 -0500
Mime-Version: 1.0
Message-Id: <E0zweKj-00079X-00@mail2.toronto.istar.net>
Date: Sat, 2 Jan 1999 22:36:05 -0500
Thanks for the tip, Joel ! Might be worth a try - sure sounds
better than RivNuts ...
....bobp
----------------------------orig.-------------------------------------
Mime-Version: 1.0
....bobp
spinning.Wicks sells a type they call 'NutSerts'. I've used them a few times and
tool works great.
Joel
Subject: Re: Elevator ;Rudder TIPSHave tried Rivnuts - generally NOT a good idea! They almost always
Received: from albedo.net (ppp137.albedo.net [206.51.22.156])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id JAA25014
for <murphy-rebel@dcsol.com>; Sun, 3 Jan 1999 09:17:05 -0500
Message-ID: <368F7B21.6ADF9F87@albedo.net>
Date: Sun, 03 Jan 1999 09:13:53 -0500
X-Mailer: Mozilla 4.05 [en] (Win95; I)
MIME-Version: 1.0
References: <E0zweKj-00079X-00@mail2.toronto.istar.net>
I am leery of using these things. Seems that it would be relatively easy for
crack to start from the "teeth" they cut in the hole.
MIME-Version: 1.0
thatWicks sells a type they call 'NutSerts'. I've used them a few times and
spinning.digs into the sheet metal you are installing them in. Even in thin sheet
installationThey have a special tool to install them with, but the rivnut
tool works great.
Received: from [137.186.227.169] (helo=ms02-169.tor.istar.ca)
id 0zwxTH-0004rQ-00; Sun, 3 Jan 1999 19:02:11 -0500
Mime-Version: 1.0
Message-Id: <E0zwxTH-0004rQ-00@mail2.toronto.istar.net>
Date: Sun, 3 Jan 1999 19:02:11 -0500
Hmmmmm - seems like there is no easy way !! I assumed that the 'teeth'
were not TOO sharp, or high, in which case, they would just help the grip
a bit. You raise a good point - it might still be worth looking a one of
the 'NutSerts' - just to see how bad it might be. The tip fairings aren't
really a high-stress location, so a little crack might not be a major
problem....
Whatever you do, it will likely be better than the 1/4" hole you
eventually end up with if you use sheet metal screws !! :-)
....bobp
------------------------------orig.--------------------------------
Mime-Version: 1.0
problem....
....bobp
for aI am leery of using these things. Seems that it would be relatively easy
andcrack to start from the "teeth" they cut in the hole.
Bob Patterson wrote:Thanks for the tip, Joel ! Might be worth a try - sure sounds
better than RivNuts ...Wicks sells a type they call 'NutSerts'. I've used them a few times
thatthey seem far superior to the rivnuts - they have teeth under the head
sheetdigs into the sheet metal you are installing them in. Even in thin
spinning.metal, they are very secure. I can't imagine them coming lose and
ortool works great.
more
