Received: from sps1 (3Cust78.tnt4.krk1.da.uu.net [208.254.2.78])
by smtp1.mailsrvcs.net with ESMTP id XAA01322
for <murphy-rebel@dcsol.com>; Sun, 20 Dec 1998 23:05:58 -0600 (CST)
Message-Id: <199812210505.XAA01322@smtp1.mailsrvcs.net>
Reply-To: <paxhia@gte.net>
To: "Murphy Rebel Mail Server" <murphy-rebel@dcsol.com>
Subject: SR2500 Flaps
Date: Sun, 20 Dec 1998 21:07:40 -0800
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1161
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
At Arlington the 2 nd factory airplane had the new flap system. The
alerions now reflex when the flaps are engaged. The flap control lever was
moved from overhead to the floor (Johnson bar style). This is the good
news, the concern I have is the flaps are controlled by a cable that exits
the top of the fuselage and runs on outside top of the airplane to the flap
control arm. This cable was covered by a 3-4 foot long fiberglass fairing.
I am looking for an alternative to the outside cable and fairing. I plan
of floats in the future so electric flaps are low on the priority list.
Does anyone have any ideas? The Beaver used hydraulic flaps, does anyone
know how that system performed and does a hydraulic system make any sense
for the SR?
Al Paxhia, SR 026
SR2500 Flaps
SR2500 Flaps
Received: from Luscomb806@aol.com
by imo17.mx.aol.com (IMOv18.1) id EMNGa24265
for <murphy-rebel@dcsol.com>; Mon, 21 Dec 1998 11:09:02 -0500 (EST)
Message-ID: <d82cb765.367e729e@aol.com>
Date: Mon, 21 Dec 1998 11:09:02 EST
Mime-Version: 1.0
Subject: Re: SR2500 Flaps
X-Mailer: AOL 4.0 for Windows 95 sub 226
Al, I didnt like the new flap system either. I went to elecric flaps . I
but a 500 lb torc motor on the floor just aft of the right door and ran a
push rod up to the flap horn. the flaps work very nice. between the door
post
and the small window. If you want more info let me know.
Les vincent SR24
Mime-Version: 1.0
post
Les vincent SR24
SR2500 Flaps
Received: from sps1 (1Cust206.tnt14.krk1.da.uu.net [208.253.25.206])
by smtp1.mailsrvcs.net with ESMTP id VAA11845
for <murphy-rebel@dcsol.com>; Wed, 23 Dec 1998 21:26:01 -0600 (CST)
Message-Id: <199812240326.VAA11845@smtp1.mailsrvcs.net>
Date: Wed, 23 Dec 1998 19:28:27 -0800
X-Priority: 3
MIME-Version: 1.0
Les, I would like more info on your flap drive design. Tell me more about
the motor (type, mfg. supplier, etc.) and how did you build the drive
linkage? How did you modify the flap horn? Thanks, Al Paxhia
X-Priority: 3
MIME-Version: 1.0
IFrom: Luscomb806@aol.com
Date: Monday, December 21, 1998 8:09 AM
abut a 500 lb torc motor on the floor just aft of the right door and ran
postpush rod up to the flap horn. the flaps work very nice. between the door
Les vincent SR24
SR2500 Flaps
Received: from DARNELLNTSRVR (darnellntsrvr.vnet.net [166.82.193.47])
by smtp2.vnet.net (8.9.1a/8.9.1) with SMTP id OAA20238
for <murphy-rebel@dcsol.com>; Thu, 24 Dec 1998 14:08:06 -0500 (EST)
Message-ID: <001801be2f70$dff79560$0118a8c0@DARNELLNTSRVR.DARNELLDOM>
Date: Thu, 24 Dec 1998 14:08:57 -0500
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.72.3007.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3007.0
Les, I would like information as well. If not too much trouble, please post
anything you have on it to the group. Thanks!
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Wednesday, December 23, 1998 10:26 PM
MIME-Version: 1.0
X-Priority: 3
----------IFrom: Luscomb806@aol.com
Al, I didnt like the new flap system either. I went to elecric flaps .abut a 500 lb torc motor on the floor just aft of the right door and ranpostpush rod up to the flap horn. the flaps work very nice. between the doorand the small window. If you want more info let me know.
Les vincent SR24
