used rebel - kit changes
Posted: Sat Feb 18, 2012 1:42 am
by bransom
Hi all,
I'm considering a couple of partially completed Rebel kits that were new in
mid-90s. Two current possibilities (1994 and 1995) both have the better
wheels and brakes, and formed windscreen that Murphy apparently changed to
after the first few years. I'm also aware of a revised plans set Murphy
released in 1999, which I'd have to get. Both of these builders got as far
as rib attachment to one wing, stopping at wet wing construction. :)
I'm trying to decide whether to take on some uncertainty risks (and cost
savings) of buying a used kit, or just get a new kit from Murphy. What kind
of changes are there to the kit since mid-90s? Would any of the changes
require much in the way of different parts/materials, or are they mostly
revisions to build methods?
Thanks in advance,
-Ben Ransom
by Gary Buster
Ben... contact me direct at mrgcb@netcommander.com ... I've been ordered by
the divorce judge to sell my partially assembled Rebel...... along with the
Lycoming, and the prop.... they want it liquidated by Feb 1st....
Obviously, I'm a motivated seller!!!
Gary Buster
Bridgeport, Texas
Sent: Tuesday, January 07, 2003 2:57 PM
Subject: used rebel - kit changes
Hi all,
in
far
kind
Thanks in advance,
-Ben Ransom
To unsubscribe, send e-mail to list-server@dcsol.com with
UNSUBSCRIBE murphy-rebel in the message body on a line by itself.
Sorry to hear of another case of AIDS (Aviation Induced Divorce Syndrome)
and it's a shame that you don't even get to keep the airplane!!!
Good luck!
Sent: Tuesday, January 07, 2003 4:26 PM
Subject: Re: used rebel - kit changes
by
Gary Buster
Bridgeport, Texas
Hi all,
in
far
kind
Thanks in advance,
-Ben Ransom
Ben, I don't know what you are refering to with "a revised plans set Murphy
released in 1999" as there are no plans supplied for the Rebel, but I
suppose that you are refering to a manual update. In some cases having the
latest update can add confusion to an older kit but probably a good thing to
pick up and compare both and decide which route to take with construction.
As for date of kit, other than upgrading to supplying the formed windshield
around late 1993/early 1994 and the newer JDM 3 piece wheels there are no
significant changes right from 1991, other than the FUS-30 (last tail cone
piece) got thicker to .032 and the lower Fus-10's (.020") got upgraded to
Fus-70's (.025") from the door post to the firewall. All these things are
already upgraded in 1994 kits. They were already done by the time they got
to serial #240 in '93 and the two piece tail spring attach came soon after
that so either kit should be as up to date as buying one direct in 2003. If
you find a great deal with good workmanship why not get a jump start.
Sent: Tuesday, January 07, 2003 3:57 PM
Hi all,
in
far
kind
Thanks in advance,
-Ben Ransom
by Legeorgen
Ben,
I purchased a presold kit from December 93. In addition what Wayne said... I
purchased, from MAM, elevator pulleys not included with my kit. And I applied
most of the Ontario MOD's that have been discussed on the list and can be
looked up in the archives. Go to the MAM web site and down load all the
service bulletins and upgrades listed with their dates and compare them to
your kit.
My preformed windshield, that came with this kit, required a center brace
that I didn't think I was going to need. It was popping in and out from wind
compression.
You should not have a problem with a used kit and I would not hesitate to do
it again and save a few bucks. Make sure the previous owner did quality work.
If you're not sure, have a knowledgeable friend or A&P evaluate the work with
you.
This is a great airplane and I'm sure you will not be disappointed.
Bruce 357R
Bruce/Ben, must have been one of the very first moulded windshields. I know
that Robin Dyck noted the same pop in and out and couldn't peg a speed at
which it came in at but said he sure knew when it went out (as it scared the
shit out of him when it did!). They then had L&P mould more of a compound
curve into it on future windshields and they do not need the center brace
anymore. I ordered my first moulded windshield on Sept 12, 1994 and it had
the compound curve across the center section and didn't need a brace.
Sent: Tuesday, January 07, 2003 8:33 PM
Ben,
applied
your kit.
wind
compression.
do
work.
with
you.
Bruce 357R
by Murray Cherkas
Hi Ben:
My wings are 1995, wings 1997 & 2001.The only change I know of was the wing
spar doubler at the strut attach fitting.There are a few mods and some
upgrades which I would build into the kit but these are not basic kit
changes.To get an educated opinion I think I would talk to MURPHY.
Good Luck
Murray Cherkas
Rebel 505
Murray, do you have 3 wings on your Rebel??
I guess none of us here are educated??
Sent: Tuesday, January 07, 2003 11:51 PM
Subject: RE: used rebel - kit changes
Hi Ben:
wing
Good Luck
Murray Cherkas
Rebel 505
by Murray Cherkas
CAN"T YOU READ BETWEEN THE LINES, YOU KNOW I MEAN'T TO SAY THE FUSELODGE IS
1995, 1 WING 1997 AND 1 2001.
DAH!
