Firewall Blanket
Posted: Sat Feb 18, 2012 1:34 am
by steenson
Good morning, all!
Have you tried other firewall covering options other than the quilted blanket
that the Murphy demonstrators appear to use. I'd appreciate some guidance
here.
Many thanks!
Jeffrey Steenson
Elite 714
Firewall Blanket
by murtech
Hey Jeffrey,
Nope, the quilted blanket is all we use...works great on the SR monster,
where the firewall gets hot enough to burn your toes!
Regards
Brian Godden
Murphy Aircraft Mfg. Ltd.
bgodden@murphyair.com
Sent: Monday, November 25, 2002 11:02 AM
Subject: Firewall Blanket
Good morning, all!
blanket
here.
Many thanks!
Jeffrey Steenson
Elite 714
Firewall Blanket
by Bob Patterson
Hi Jeffrey !
If you want to keep weight & bulk down, there's a fireproof
material called "FiberFrax" (??) from Aircraft Spruce, that's only
about 1/8" thick. It's a white woven ceramic that is bonded on with
a silica adhesive that comes with it - both are suitable for EITHER
side of the firewall. It will reduce heat transfer, and can be painted
with HT paint....
If you want more sound absorbtion, after the FiberFax, you
could use the plastic "bubble pack" that many builders use everywhere -
in the doors, on the roof, as a 'curtain' to close the fuselage
behind the baggage area, etc. This stuff is used for barn & chicken
coop insulation - it's like plastic bubbles, with silver foil on
both sides, so it's good heat and sound absorbing. It comes in rolls,
at farm or hardware supply houses, and is LIGHT & CHEAP !! It can be held
in place with velcro strips, or just spray contact cement, and you
can also glue lightweight automotive upholstery material to it,
for a nice finish !!
-------------------------------------orig.-------------------------------
At 10:02 AM 11/25/02 -0900, you wrote:
Good morning, all!
here.
Many thanks!
Jeffrey Steenson
Elite 714
