Bulkhead cracks on 1800 Floats
Now that your all have your floats together.......... I thought I should
share this with you.
When I split the 1500's and stretched them 21", to make them into 1800's
this spring/summer, I found that <ALL> the partial bulkheads in the step
area were cracked in the center right above the float keel area. I thought
maybe this was due to improper construction when the factory first built
them as these were one of, if not, the original set of 1500 amphibs. While
putting Howard's A/C "to bed" for the winter, today, I noticed that his
floats are now showing this cracking as well on all the step area partial
bulkheads.
I have posted a picture of the cracks to the archives files and also how I
tackled repairing the floats that I stretched. If you still haven't closed
your floats, or installed your "stringer" stiffeners, I would be tempted to
put flanges on these gussets and install them on the inner face of the
bulkhead to add some more stiffness. Gusset is basically a half moon of .032
material
Still great, light, floats guys/gals and for those that have followed my
posts about drilling the axles and filling the main wheels with grease for
bearing longevity, be reassured that Howard's chrome plated wheel bearings
have survived a 5th summer on the water. After blocking his floats, so his
gear was off the floor, I have simply pumped a fresh cartridge of synthetic
boat trailer grease through them while rotating the wheel, 'till the water
stopped showing in the expelled stuff and they are ready again for next
spring. This time frame is simply amazing considering that the first set of
chrome plated ones didn't last a month when they were just hand packed per
the assembly manual. Leaving them that way just let the wheel fill with
water, becoming a centrifuge to wash the bearings clean of all grease. I
also figure if we are getting a 6th season out of the bearings I can now
comfortably state it is not worth the time to disassemble the entire
assembly every year to clean and refill. $400 for bearings/6 years = only $6
6.67/year, so far, so why spend countless hours taking them apart and
putting them back together unless you are absolutely bored and have nothing
better to do!!
bulkheads.
material
better to do!!
Wayne, thanks for sharing. This is what makes this list
so valuable. Sometime later this winter, I am going to
give my floats a full going over after one full
season's use, and will be sure to really check these
partial bulkheads carefully. Looks like a simple fix,
so hopefully I can still prevent the problem from
happening on mine.
Archives located at
happening on mine.
http://www.dcsol.com:81/public/listserv.htm-----Original Message-----
Sent: Monday, November 11, 2002 5:33 PM
Subject: Bulkhead cracks on 1800 Floats
bulkheads.
material
better to do!!
To unsubscribe go to
Archives located at
Problem is Walter, how can you fix it once they are all together?? Even
Howard's with his baggage door, that is about 16" long, would be a hard job
to work through. You sure can't do it through the 6" round holes unless you
have two in the step compartment, like the 1500's I have do, so you can
stick an arm in each hole.
Sent: Tuesday, November 12, 2002 8:54 PM
Subject: RE: Bulkhead cracks on 1800 Floats
*-------------------------------------------------------------------------*Wayne, thanks for sharing. This is what makes this list
happening on mine.
bulkheads.
material
better to do!!
Archives located at
Thanks for the info on the float damage. Mine look OK!
What is the bottom skin thickness on these floats that you are repairing. (.032?)
Steve Sloan
Steve Sloan
Steve, Howard's have taken 5 summers to start showing this deformation and cracking. I don't think it's a big deal, just thought I would nip it for others before they closed up their floats. Howard's bottoms in the step area are .032 and all the bulkheads are MAM's standard .025.
Sent: Wednesday, November 13, 2002 5:44 PM
Subject: Re: Bulkhead cracks on 1800 Floats
Steve Sloan
Yeah, I'll have a look this weekend, but I see your
point. It won't be the first time that I have had to
drill blindly and do stuff by feel on the Rebel.
I assume it's rough water landings that does it. I have
learned to touch down slowly and gently in these
conditions, but have not found a way to avoid the
beating you get for those 3 seconds when coming down
off the step.
Thanks also for looking in your special drawer for the
bolts. I am still on the hunt. I've got a local prop
shop phoning around their other locations to see if
they can locate a used set.
off the step.
Sent: Thursday, November 14, 2002 1:41 AM
makes this listWayne, thanks for sharing. This is whatam going toso valuable. Sometime later this winter, Icheck thesegive my floats a full going over after one full
season's use, and will be sure to reallysimple fix,partial bulkheads carefully. Looks like amike.davis@dcsol.comso hopefully I can still prevent the problem from
happening on mine.
bulkheads.
material
better to do!!
Archives located at
-----------------------------*http://www.dcsol.com:81/public/listserv.htmTo unsubscribe go tohttp://rebel:builder@www.dcsol.com:81/default.htmArchives located atmike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
My float kit came with the heaver .040 bottoms that should help spread the load .
To date I have a little over 50 hrs on the floats with approx. 175 landings.Great fun!!
Steve Sloan
Steve Sloan
At 08:32 PM 11/11/2002 -0500, you wrote:
Thanks for the heads up. Just finished adding gussets to my second float.
I knew there was a reason I was procrastinating about closing it up. I'm
wondering if you found any cracking on the F bulkhead and if not do you
think that the sealant acts like some kind of shock absorber. It would be
very dificult to add gussets to my first float but pretty easy to slide a
plastic straw under the bulkhead to let water through then add a fillet of
sealant up each side of the bulkhead.
bulkheads.
material
Hi Wayne
Drew, just the partial bulkheads seem to do this. Haven't seen any
deformation of the full compartment end bulkheads, including the one that
has the drain area at the keel for the section between the attach/spreader
double bulkhead set. In your completed float, you could probably even cut a
doubler and then just coat the h... out of it with Proseal or Sikaflex and
simply bond it on to the partial bulkheads to add some strength.
Hi Wayne
That was my origional plan I even cut enough gussets out to do the other
float that way.
float that way.
-----------------------------------------------------Drew, just the partial bulkheads seem to do this. Haven't seen any
Hi Wayne
