I've helped on a couple Zenith's (which also use 6061), and the builder's
have either used "automotive" self etching primer, or no corosion protection
at all (no zinc chromate, etc).
The other substances that I've read being on the Zenith list are zinc
chromate, zinc oxide, zinc phosphate, "self-etching primer", and a couple
marine products. Probably the most helpful suggestion that I've heard is to
go into a marine supply shop and ask what they have for a particular
material (the stuff they use for aluminum is different than steel (engine
mount, etc) on a boat).
The other item that I've read is that the zinc does the work. Chromate, is
supposedly the poisonous stuff.
My experience with the self-etching primer is that it didn't seem to have
any negative effect on the aluminum, but on the planes where this was used,
primer was used lightly (as in, just enough to cover, not coat, you could
easily see the lettering through the primer).
My comment: This is 6061, it's not going to be as prone to corrosion as a
aluminum that has copper or another material that will cause a galvanic
response. There is a posibility of some interaction between the rivets and
the aluminum, but that's pretty remote. There are planes over 30 years old
now that have built with the materials and processes that we use now, and
are still flying. One of the more famous is Chris Heintz's original
homebuilt, 6061 with stainless steel rivets, bare aluminum, no zinc
chromate. It's been sitting outside for ~25 years, and still doesn't have
any corrosion, according to Chris.
So, do what makes you feel comfortable. But I wouldn't poison yourself just
to try to protect 6061.
I'll be using self-etching primer, at this point, unless I find out
something to the contrary.
Rob Luce
Rebel tail on order
klehman@albedo.net>
To: <
murphy-rebel@dcsol.com>
Sent: Sunday, October 20, 2002 11:30 AM
Subject: Re: Primer Alternative
I gather self etching primer is a nice product at controlled thickness
on an outer surface. I have always been curious though as to what stops
it from etching too much if you happen to get a very thick layer of it
in a seam or joint? I've heard rumours of problems but never any
substantiating evidence.
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
