RR5602 SS Rivets
S & L Aldrich
RR5602 SS Rivets
Post by S & L Aldrich » Fri Feb 17, 2012 10:24 pm
Hi guys, asked MAM this but they don't seem to be home.
Just riveted the collars that hold the control column torque tube in place.
It uses the RR5602 SS according to plans. None of the stems stayed in, they
are all hollow. Did a test and got the same result. Do these not keep the
stem inside like the others??
Scott
RR5602 SS Rivets
Post by Bob Patterson » Fri Feb 17, 2012 10:24 pm
Hi Scott !
As Far As I Know, all Avex rivets have their strength
calculations based on "without the mandrel", so, if it stays in,
thats just a bonus !
If you are dipping all rivets (and especially the SS ones !)
in Polyfiber Expoxy Primer, and installing WET, as recommended,
that usually helps seal and lock in the mandrel.
-----------------------------------orig.------------------------------
Scott
Al & Deb Paxhia
RR5602 SS Rivets
Post by Al & Deb Paxhia » Fri Feb 17, 2012 10:24 pm
Hi Scott,
I had the same experience with the SS rivet mandrels pulling out. I have
also had to drill out some SS rivets, they are hell for strong and not easy
to get out. I would not worry.
Al
Sent: Wednesday, September 25, 2002 5:34 PM
Subject: RR5602 SS Rivets
place.
they
Scott
S & L Aldrich
RR5602 SS Rivets
Thanks guys, I won't mess with them, the aren't doing a whole lot there
anyway.
Scott
Al & Deb Paxhia
Sent: Wednesday, September 25, 2002 9:16 PM
Subject: Re: RR5602 SS Rivets
Hi Scott,
Al
place.
they
Scott
RR5602 SS Rivets
Post by Wayne G. O'Shea » Fri Feb 17, 2012 10:24 pm
No they normally fly out as soon as they are pulled even if dipped heavily
in epoxy!
Sent: Wednesday, September 25, 2002 8:34 PM
place.
they
Scott
