Engine Questions
Posted: Sat Feb 18, 2012 1:24 am
My Rebel construction is getting to the point where I need to get serious on
the engine decision. I would like to explain my views here, and would
appreciate any and all comments.
I am building my Rebel to carry 2 adults (realistically figuring 200# each),
full fuel, camping gear for several days, and fishing gear without going over
the established 1650# gross weight. I do not have the experience and do not
anticipate flying into STOL situations, and I doubt I would ever put the Rebel
on floats.
While I would like to have 150-160 HP, given these parameters I don't foresee
using the O-320 simply because it weighs to much (255# dry wt). Given the empty
weight figures I've seen for some O-320 equipped Rebels, it seems likely to
reach gross with 2 people and full fuel without any any of the camping/fishing
gear that I'd like to carry. I don't want to have to drain fuel to maintain
gross wt limits. Someone let me know if I'm wrong about this.
However, should I ever sell the aircraft, I think it would have a better resale
value if O-320 equipped.
I like the idea of the Jabiru 3300, 6 cylinder, which the mfg. lists the ramp
weight as 180# with exhaust, carb,starter motor, alternator, ignition system,
and accessory pack. That's 75# lighter than the listed dry weight of the O-320;
39# lighter than the listed dry weight of the Lyc O-235-N2C; and 25# lighter
than the listed dry weight (w/o accessories) of the Continental IO-240-B.
So I am leaning toward the Jabiru 3300. What I'm uncertain about is the higher
RPM's the engine develops (3300 max) and how that might necessitate using a
smaller diameter prop. If I would need a smaller diameter prop, how would that
affect overall performance compared to an engine developing less max rpms but
using a larger diameter prop? Would an in-flight or constant speed prop
(Airmaster or Quinti) overcome some of the performance issues of a smaller
diameter prop?
I found a Propeller Tip Speed Calculator at www.altimizer.com/propspd.html
which says "to produce maximum thrust from your propeller at full power your
tip speed should fall between .88 and .92 mach....This of course varies
depending on your particular propeller and the temperature". Using the
calculator with a 70" prop diameter, 3300 prop rpm's, and ambient temp of 70
deg F produced a tip speed of 0.894 mach. A 72 inch prop under the same
conditions reached 0.919 mach, just shy of the upper limit. I noted that tip
speeds increased as the ambient temp decreased. What ambient temp should you
use to make the proper determination? What happens when prop tips exceed 0.920
mach?
This is all stuff I am trying to understand so that I can make an informed
decision.
So anyway, I would appreciate any discussion anyone might have regarding this.
I searched through the archives for 'Jabiru'. There was some discussion, though
mostly regarding the smaller engine (2200), and at least one other builder
indicated he would be installing the Jabiru 3300.
Roger Hoffman #687R
Eugene, OR USA!
on floats.
diameter prop?
mach?
decision.
Roger Hoffman #687R
Eugene, OR USA!
