Hi Michael,
No mine was the slow build tail. The rest is fast build. Here are the build
times in hours.
Stabilizer: 65.4 (still need to add hinge bushings and reinforce tip
hinges)
Elevator: 66.6 (still need to make fix for interference with aft fin spar)
Rudder: 37.5 with addition of electric trim tab.
Fast build parts:
Ailerons: 20 (includes adding anchor nuts to all inspection holes)
Flaps: 16
Wings 36!! (still have to finish wing tips, and pressure test tanks)
One bucket seat back 40 minutes..
and that's as far as I am.
Scott
N174SL
Michael Bleau
Sent: Tuesday, September 03, 2002 10:21 AM
Subject: RE: New to the BBS
Hello Scott,
I was wondering if you might be able to give me an idea on some of the
construction times. Did you get the fast build tail? I am going to be
starting shortly on the fast build tail, but have not built a plane before
so I will likely be asking lots of questions on this site as we progress.
Thanks. Also if anyone else has their times it might be interesting to do
some averages. Thanks again.
