I've written to Brian Godden at MAM about the hinge reinforcements. His reply
is that they used .032 material that was cut to fit across the web of the spar
and match to the shape of the rib on the other side. The legs should each be
3" long, and use one inch rivet spacing. He agreed that it would make no
difference if the reinf. were inside or outside the stab. Mine will go inside
(cleaner final look and I won't have to make a new hinger "packer" to maintain
hinge alignment). Finally, he recommends using lots of Pro-Seal.
Anybody else have other ideas before I start making mine?
Terry Riedel
SR 171
Moose outer stab hinge reinforcement
Are you talking about the vertical stab? Fast-build?
Steve Rhodes
SR 173 Fast-Build
Sent: Monday, August 26, 2002 12:57
Subject: Moose outer stab hinge reinforcement
Steve Rhodes
SR 173 Fast-Build
replyI've written to Brian Godden at MAM about the hinge reinforcements. His
sparis that they used .032 material that was cut to fit across the web of the
beand match to the shape of the rib on the other side. The legs should each
inside3" long, and use one inch rivet spacing. He agreed that it would make no
maintain(cleaner final look and I won't have to make a new hinger "packer" to
*-------------------------------------------------------------------------*hinge alignment). Finally, he recommends using lots of Pro-Seal.
Terry Riedel
SR 171
On 8/28/02 8:52 AM, RHODES5@GCI.NET wrote to MURPHY-REBEL:
Hi Steve,
This is in regards to the reinforcing that MAM has done on the prototype's
horizontal stab. Apparently the radial/paddle prop combo really beats up the
airframe. Murphy has installed a brace under the outer hinge that ties the
rear spar and outside rib together more securely.
If you look in the S files, Tail, Scott Aldredge posted a picture he took of
that area. I believe this will apply to both fast and slow build aircraft.
Terry Riedel
SR 171
-> Are you talking about the vertical stab? Fast-build?
-> Steve Rhodes
-> SR 173 Fast-Build
-> From: <moose2b@dcsol.com>
-> Sent: Monday, August 26, 2002 12:57
-> Subject: Moose outer stab hinge reinforcement
-> > I've written to Brian Godden at MAM about the hinge reinforcements. His
-> reply
-> > is that they used .032 material that was cut to fit across the web of the
-> spar
-> > and match to the shape of the rib on the other side. The legs should each
-> be
-> > 3" long, and use one inch rivet spacing. He agreed that it would make no
-> > difference if the reinf. were inside or outside the stab. Mine will go
-> inside
-> > (cleaner final look and I won't have to make a new hinger "packer" to
-> maintain
-> > hinge alignment). Finally, he recommends using lots of Pro-Seal.
-> > Anybody else have other ideas before I start making mine?
-> > Terry Riedel
-> > SR 171
-> > To unsubscribe go to http://www.dcsol.com:81/public/listserv.htm
-> > Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
Hi Steve,
Terry Riedel
SR 171
-> Steve Rhodes
-> reply
-> spar
-> be
-> inside
-> maintain
-> > Terry Riedel
-> > SR 171
