Rebel vs. Elite
Posted: Sat Feb 18, 2012 1:21 am
Hello Mike,
Let's see, are blondes better than redheads? Hmmmmm.... We are building an IFR Elite taildragger with O-360 power. It may go on floats but into the air first. We got our kit in Oct of '97 and there is still not a kit on the market that I would prefer. We picked the Elite for all aluminum construction an ability to use 180 hp. Given the extra gross versus the extra weight the real useful load is probably a tossup. We will be at high density altitudes and the 180 hp seemed like a good choice but I believe a good light Rebel with 150 or 160 hp would provide equivalent performance. I personally would go with the 150hp as I don't think the 160 can use auto gas. (Someone may correct me on this) I would not use electric flaps on the Elite as the mechanical system is simple. Any homebuilder will tell you that modifications are like pulling a sweater thread - there is no end! If you must have a tricycle gear then it has to be the Elite. Also, the Elite cabin has a few less parts and is probably easier to build. There is also an Elite fast build kit that is a real jump start if you have the money and want to fly sooner.
This is one of those nicer questions where there is really no wrong answer. If I were starting over and did not need fast build, front training wheel, and didn't care about fabric I would lean toward the Rebel for essentially equal performance, lower cost, and the bunches of cheaper O-320 engines available. As a kind Rebel builder told me after a great flight in his beautiful Rebel, "I don't know any Rebel or Elite owners who aren't happy with their plane".
If you are certain about float use consider extra corrosion protection. Also, floats or not I suggest adding the Wayne O'Shea and Murphy "float fix" strengthening parts. We did add screw removable (not riveted) access plates and screw removable wing tips and fin tip, all in the interest of easier maintenance.
Enjoy the building process!
Ralph Baker / Sue Scouten
Elite 624E (reserved)
