throttle cable connections
Posted: Sat Feb 18, 2012 1:17 am
by Rick DeCiero
A while back someone asked what others were doing for engine cable
control connections i.e. carb heat, throttle, mixture.
My carb heat is just clamped to the control arm with a bolt and washers
and a hook on the end. The mixture is just threaded through the hole
provided on the mixture control arm (Lycoming ) and the throttle has one
of those collet type wire grips with a threaded end, Aircraft Spruce P/N
05-16000 or 05-16001 I don't remember what size the cable diameter is. I
have seen these used on many experimentals. Does anyone have any reports
on the type clamps.
Good luck, you'll need it,
Rick D.
Wayne O, if you can post some pics of your steel trailer/tailwheel
spring it would be appreciated.
Thanks.
