notam (2/5131) need transponder to go to Oshkosh
Posted: Sat Feb 18, 2012 1:17 am
Forwarding this as I <presume> the EAA office knows what they are talking
about. They say you need a transponder to fly to Oshkosh, if you have an
electrical system! Haven't taken the time to figure out if this is because
of a local NOTAM or the requirement to cross the USA border.
To: "RAA Forum" <RAA-Forum@raa.ca>
Sent: Tuesday, July 09, 2002 10:52 AM
Subject: Fw: notam (2/5131) need transponder to go to Oshkosh
an*This message was transferred with a trial version of CommuniGate(tm) Pro*
for your interest.
To: 'Gord Reed'
Sent: Monday, July 08, 2002 6:49 AM
Subject: RE: notam (2/5131)
Gord,
Yes, all flights must comply with the international flight NOTAMs,
regardless of whether coming to AirVenture or not. If your aircraft has
thiselectrical system, you'll need a transponder. If your aircraft does NOT
have an electrical system, you can apply for a waiver for the flight at
ensureweb site:
http://www.intl.faa.gov/displaypage.cfm?id=22
Hope this helps!
Joe Norris
EAA Aviation Information Services
EAA Aviation Center, Oshkosh, WI
888-322-4636, extension 6806
jnorris@eaa.org
We are pleased to provide this info as an EAA membership benefit. To
ofthat this service continues, renew your membership or join EAA today by
calling 800-843-3612 or 920-426-5912.
Flying to EAA AirVenture Oshkosh? Be sure to download or order your copy
aircraft.the required NOTAM at: http://www.airventure.org/2002/flying/notam.html
Visit EAA on the web at http://www.eaa.org/
Sent: Sunday, July 07, 2002 9:59 PM
To: infoserve@eaa.org
Subject: notam (2/5131)
Question for Canadian pilots in amature built Canadian registered
Do we have to comply with 2/5131 if we get a waiver from the FAA?
The Queation is really can I fly to Oshkosh without a transponder?
Gord Reed
EAA # 90150062
This message is sent to you because you are subscribed to
the mailing list <RAA-Forum@raa.ca>.
To unsubscribe, E-mail to: <RAA-Forum-off@raa.ca>
To switch to the DIGEST mode, E-mail to <RAA-Forum-digest@raa.ca>
To switch to the INDEX mode, E-mail to <RAA-Forum-index@raa.ca>
Send administrative queries to <RAA-Forum-request@raa.ca>
