I ordered mine last week based on the following email exchange
"I have a Rebel with an 0-320, aluminum cowl. I bought Van's baffle and it
worked great. I'm glad I didn't convince myself to try and make my own
although this can be done.I mounted the oil cooler on the firewall not on
the baffle. I would definitely by Van's baffle if I were to do it over
again.
With the speed cowl you probably will have to cut a little more off the top
to make it fit.
Good Luck
Murray
kboliver@adelphia.net]
Sent: Sunday, September 28, 2003 5:04 PM
To:
cherkas@shaw.ca
Subject: Van's Baffles
Hello, I was just about to begin on my engine baffles (0-320) and
remembered that you had mentioned using Van's baffles instead of making your
own.
?? How did they fit and what cowl are you using
I have an Elite with a speed cowl
Your input would be welcomed "
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of
Sent: Sunday, October 05, 2003 12:19 PM
To:
murphy-rebel@dcsol.com
Subject: engine baffles
Vans has a baffle kit for the O-360 and O-320 that has the baffles cut
out and many bends made. Not to throw money in the path of "recreation
and education" (FAA euphemism) I like the looks of the Van's kit a lot
better than the flat stock and templates. Still waiting for a Speed
Cowl from MAM to determine fit but a local RV-8 builder said he had to
trim off the baffle tops so presume I can make it fit.
Elite 624E
Archives located at
https://rebel:builder@www.dcsol.com/default.htm
To contact the list admin, e-mail
Archives located at
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
