Fiberglassing
Posted: Sat Feb 18, 2012 1:13 am
Hello,
If anyone has added bumps for the exhaust on a standard rebel speed
cowling could you please let me know if the filler coat on the cowl
exterior needs to be completely sanded off before glassing on the
additions. By completely, I mean only where the new glass will be stuck
on. I will be using an epoxy resin to secure the glass to the cowl. The
filler coat is quite thick. Does anyone know what material it is? The
elevator and rudder tips have the same filler coating. I glassed on the
ends of the tips without removing the coating. Do you think this will be
a problem? It seems to have adhered very well. I have laid up a couple
of test pieces to see how they will survive a destructive test but I
don't Know what the long term effects will be. My first test has a 2"
square area bonded to the filler coat without any preparation other than
wiping clean with solvent.
The second test piece has the filler coat sanded with 180 grit paper but
not sanded down to the base fiberglass. Also a 2" square patch. In the
third test, I sanded right down to the fiberglass and boned the patch to
it. All patches have an epoxied end with a hole in it so that I can pull
on it with a scale attached. This will establish some data with a peel
strength relating to the preparation of the surface. I am not sure what
will be an acceptable number and it seems that the one bonded directly
to the fiberglass should be the strongest.
Rick D.
Good luck, you'll need it.
Rick D.
