I put new bottoms on a set of 1650A floats a few years back. Put them on a
C150 and was the worst combination for a floatplane I ever experienced. I
cannot believe it was certified. The 150 did not have enough wing or power.
The 1650A's did not ever seem to plane on step well. I think the e "V" is
too deep for the length to the step. I was lucky to sell them for what I had
in them. (not my time just my cost).
George Coy
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of Wayne
G. O'Shea
Sent: Friday, April 18, 2003 5:03 PM
To:
murphy-rebel@dcsol.com
Subject: Re: 1800 floats
Steve, if you love the EDO line so much, why not pick up a set of 1850's
from a C150/152 and make up some mounting gear?? If they don't work right
remove the mounting gear and put back the C150 mounting and they'll still be
certified with a wide open market for resale!
What I don't like about EDO and the likes is the lower number of separate
compartments (MAM's have EIGHT/float!). I was amazed when I looked inside a
set of EDO1650's thinking I could easily turn them into a set of amphibs by
bolting a gear assembly to the step bulkhead, only to find that there isn't
even a bulkhead at the step and that it is one long giant hollow
compartment.
Corrosion resistant 6061T6 vs corrosion susceptible 2024T3! Huummmm! May be
as many possible negatives as plus' going either way. Also since 2024 is
harder and breaks easier (evident by the 3x as much bending radius 2024
needs over 6061) is it not possible that the 6061 just may dent on a rock,
where as the 2024 will tear a hole! I don't know just speculating!!!!!!!
srwhitenect@hotmail.com>
To: <
murphy-rebel@dcsol.com>
Sent: Friday, April 18, 2003 2:03 PM
Thanks for the reply, Drew. I,ve had the North Air drawing for years. They
are extremely heavy for their size. I,ve built 2 complete sets of other
floats plus alot of repairs and yes there is alot of parts. I flew in
Newfoundland for a number of years and they don't call it the "Rock" for
nothing. For serious float flying, 2024 is the best for construction from
my experiences thus far in life. From working with the 6061 and
accidently
releasing my cleco plyers too quickly, I've experienced the end result of
several dents in the .020 skins. ( all plyers now have a wad of tape on
lower handle ends!) Talked to a buddy a few minutes ago and he has the
Zenith 1900 plans. I'll see they next weekend.
When I first looked at the Murphy straight 1800's they were on special for
about 5200cdn, now asking 9200. I had full intentions on using the kit
skins for templates only and use the 2024 for all of the exterior.
Steve w
scale them up to suit yourself. I bought a set of 1800 amphibs and while
they are expensive I feel I got fair value for my money. There's an awful
pile of parts that go into a float plus some custom extrusions.
At 09:16 PM 4/17/2003 -0800, you wrote:
Anyone know of kits available in the 1800 size other than Murphy? Find
their
kit too pricey for 6061-T6. Am an old EDO fan and draw the line on the
soft
metal verses 2024. Might be designing my own if I can't find something
else.
Would build a set of Cap 1800's if I could find a set of bulk heads.
Have a
set of EDO 1650's for my Christavia with new skins top and bottom, new
angle,
chines etc. but won't sell them till I start on another set for the
Rebel.
Requested info from Aqua but they look quite stubby and are a bit on
heavy side. Any Bites?
Steve W.
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
Archives located at
To contact the list admin, e-mail
Archives located at
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
