Terry!
If you received a moulded windshield, post 1995, it DOES NOT need the center
brace tube. Only the, very few, very first ones did (mine installed winter
1995 did not). They now (for the last 7+ years) have a proud spot moulded
into them that keeps them from popping in from air pressure in flight.
Also DO NOT drill any holes into the windshield like the original
installation showed. The windshield can be fitted and the retainer laid up
to hold it in place without any holes being drilled into it. This allows it
to free float, without a 100 holes to start a crack from.
The forward skylights (eyebrows) will need to be cut out before final
installation, as the windshield covers this area to the first cabin
bulkhead. I also like to leave the windshield out, if you plan on painting
before flight, as this allows the instrument deck and the "eyebrow" area,
carrythrough etc to be painted into your scheme.
I still prefer to use the aluminum strip, that was supplied in the older
kits, to retain the windshield sides and top, which then only requires
laying up a fiberglass retainer for the bottom edge. Then everything can be
removed, except the fiberglass retainer that can be riveted down to the deck
and sanded smooth etc and then everything painted. Then the windshield can
be put in place and the side and top retainers bolted in place. If you ever
crack a windshield at a later time, then it is very easy to unbolt the
retainers and tip the old windshield out of the lower retainer. Take some
tracing paper (or similar) and lay it out over the cracked windshield and
use an exacto knife to trim your pattern. Then tape to new windshield and
trace the pattern and trim. Throw back in with some new gooo tape and bolt
the retainers back on. As for the gooo, I prefer to still use butylene tape,
that is available from any auto/boat windshield installer (I pay my local
guy $5.00 cash for a good size roll that does about 3 windshields!). I don't
like the tube of goo that MAM has been supplying lately, as it just gets
everywhere and requires an assistant to work with it so someone can hold the
windshield back while you use a caulking gun to apply. Much easier to cut
off strips of tape and stick to the forward retainer lip and up the sides
and over the top. Then place the windshield with it tipped forward, slip it
forward against the retainer while tipping it down onto the roof and bolt
the retainers in place (practice this without the goo tape in place a few
times to get the motion right first!!). Put some thin weather stripping foam
on the inside of the aluminum retainers where they touch the windshield, so
they don't dig/wear into the acrylic. Then push the lower edge of the
windshield tight against the retainer to get the goo tape to stick and if
you can park it out in the sun to heat up and do the same again. Fill the
gap going around the leading edge area and the small gap, that usually is
present between the cabin roof and the windshield, with small strips of goo
tape and just roll and press into place to seal it off along the edge.
Think I took some pictures when I changed Charles D's from old Lexan to new
moulded windshield. If I get time later today I will post to site.
tasack@gcfn.org>
To: <
murphy-rebel@dcsol.com>
Cc: "Norm Wandke" <
newcog@aol.com>
Sent: Sunday, June 02, 2002 1:02 PM
Subject: Rebel windshield
I'm installing the preformed windshield. There are no instructions in my
manual for the preformed, only the lexan make-it-yourself one.
Is the center winshield brace still needed with the preformed?
Are there any special gotchas I should look out for? How tight a fit
should
be achieved around the wing root area? Does the wing root fairing cover
this part of the windshield?
Is there any improvement, or installation I should do around the panel
before installing the windshield permanently? I'm thinking about the
defroster holes, skylights, and the sun visors, etc. Thanks, Terry
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
