Hi Jesse !
That would be the old ULTRALIGHT Rebel kit, I guess - it has thinner
spars, thin skins, and an all-fabric tail ... and a low gross weight
(originally 1,057 lb).
You are lucky !! I love the fiberglass springs, and will continue
to use them on my Rebels as long as I can get them !! They absorb shocks
well, and have a very benign failure mode - they delaminate & let you
down slowly..... Much better than steel springs, that just snap !
And infinitely better than the solid chunk of aluminum that now comes
as a "spring" - these can work IF you machine/grind them down to
taper from about 1" thick (!) to under 1/2" at the tailwheel attach end.
You should, of course, do Ontario Mod. #1 - a doubler over FUS-30,
to tie the top bulkhead, rudder post, and front triangular pieces together,
to better distribute the loads. Even if you are building as an ultralight !
This is one area that field experience has provided a 'fix' for - and
it IS necessary !
The old, original tailwheel worked great - Rebel #001 is still flying
with that tailwheel ! It is a bit awkward for ground handling - you can't
push it backwards !! Fortunately, the old tailwheel can be retrofitted to
become a full-swivel wheel, as now shipped. There was an upgrade kit
shipped 'way back about 1993 for this, and all the parts are still available.
This is a worthwhile thing to do - it makes ground handling much easier,
and will reduce the radius of your turns, as well.
What engine are you planning ??
PS
If you are not going to use the fiberglass spring, you can toss it
my way ! :-)
On Thursday 11 August 2005 12:27 pm, Jesse Jenks wrote:
Interesting discussion. I got an older kit from Wayne O. It has the old, old
tailwheel mentioned by someone in this thread, with no castoring provisions.
I also got a fiberglass spring. Since nobody responded to the query about
how the old style tailwheel works I will ask again. Any comments on them?
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
