doubler at elev. push-pull tube
Posted: Sat Feb 18, 2012 1:08 am
Murray,
For those of us who are 'not there yet'.... If you had the chance to do it over
again would you have any suggestions/recommendations/tips for building it
differently to avoid your situation?
Thanks.
Roger Hoffman #687R
Eugene, OR USA!
On 4/28/02 7:57 AM, CHERKAS@SHAW.CA wrote to MURPHY-REBEL:
-> I installed the tail cone doubler as Wayne suggested. The doubler around the
hole runs into this doubler, also when cutting the hole for the push-pull tube
I ended up very close to the rivets for the bulkhead here. The push-pull tube
still hit the rivet heads
-> so I am going to add 2 washers onto the bolt at elevator horn to move the
tube outward so as to miss the rivet heads.You cannot now add more aluminum
here so I cut the slot in the doubler straight back. Had to drill out six
rivets on each side to attach the
-> doubler at the bulhead location.
-> Just passing on a little something I had to do.
Thanks.
Roger Hoffman #687R
Eugene, OR USA!
