Server maintenance
mike.davis
Server maintenance
Post by mike.davis » Fri Feb 17, 2012 10:04 pm
Just wanted to let the list know that I'm in the process of doing some major
server maintenance. Everything is running on a backup system at the moment.
I was having a lot of difficulties with the system running reliably and
decided it was time for a rebuild. It's been through a lot of configuration
changes over the last couple of years with all the different homes it has had,
and that can lead to reliability issues. Now that I have it in my own home
and shouldn't be making any more changes it's a good time for a ground up
rebuild. This will allow me to configure it specifically for the current
installation without all the extra stuff that has been added and deleted over
the years.
Anyway, just wanted to let everyone know what was going on in case there are
times you are not able to get on the site.
Server maintenance
Post by Bob Patterson » Fri Feb 17, 2012 10:04 pm
Thanks Mike ! Just had one little problem - and you've provided
the answer... Thanks for all the effort !
Maybe it's a good time to install Linux, while you have a
chance ! ;-) ;-) :-)
-------------------------------------orig.-------------------------------
the years.
Server maintenance
Post by Mike Davis » Fri Feb 17, 2012 10:04 pm
I don't have a couple years to try and rewrite all the software that's
running on this system to port it over to Linux... I really think the system
has done pretty well for Micro$haft! Started running it in 1997 and it's
been moved from one system to another about 5 times, changed home as many,
and it's still the original installation... just copied from one drive to
another. Not that there haven't been any problems, but not bad for all it's
been through.
Sent: Monday, April 22, 2002 1:48 PM
Subject: Re: Server maintenance
major
moment.
configuration
had,
home
over
the years.
are
mike.davis
server maintenance
Post by mike.davis » Fri Feb 17, 2012 11:12 pm
Just wanted to give everyone a heads up that the list server might be
unavailable off and on for the next few days. I've had a persistent problem
with the disk array for some time now, and today I almost wasn't able to
recover. I do have backups of the system, but it still takes a long time to
restore a system this complex from a backup. Anyway I will be working hard to
isolate the problem with the drive system and will be completing a complete
system backup which requires that I stop all network services in order to have
full access to all files... this will probably take several hours and happen
some time tomorrow.
server maintenance
Post by Bob Patterson » Fri Feb 17, 2012 11:12 pm
Thanks again for all the work you do for us !! This really
is an invaluable service to all the builders & flyers !!!!
some time tomorrow.
Server maintenance
Post by Mike Davis » Sat Feb 18, 2012 9:16 am
Just wanted to drop everyone a quick note to let you know that I'll be doing
some server maintenance today, and the system will be offline for a while.
Shouldn't be more than a couple of hours tops. Just try again later if it
doesn't respond for you.
Server maintenance
Post by Mike Davis » Sat Feb 18, 2012 10:47 am
Going to take the server down for a couple hours this morning to do a backup
and maintenance.
Server Maintenance
Post by Mike Davis » Sat Feb 18, 2012 10:51 am
Well there's still some work to do, but I think I've got most of the basics
back up and running on the new server. Right now I believe the only thing
on the Rebel Builders site that isn't working is the address book, and since
I've been at this for about 15 hours now, I'm going to save that for
tomorrow!
Try everything out, and if you find something that's not working right,
please let me know.
Server maintenance
Post by Mike Davis » Sat Feb 18, 2012 1:38 pm
It's that time again... I'm going to have the server down for a little
while this morning doing a backup and maintenance.
Server Maintenance
Post by Mike Davis » Sat Feb 18, 2012 2:01 pm
Well it's that time again... I'll be taking the server down for a couple of hours this evening to backup and perform maintenance on.
Server Maintenance
Well the wife came home last night and I found out that I had plans... so
I'll be doing the maintenance today. ;-)
Sent: Thursday, October 20, 2005 5:25 PM
Subject: Server Maintenance
Robert White
Server Maintenance
Post by Robert White » Sat Feb 18, 2012 2:01 pm
Sounds like fun Mike...is there anyway I can have all the new messages to
the web site that come to my email stopped...I wanted access to the website
to browse but am not particularry interseted in getting all the new
posts.........RJ White
Sent: Friday, October 21, 2005 4:04 PM
Subject: Re: Server Maintenance
Server Maintenance
Sure, there's a link at the bottom of every message...
Sent: Friday, October 21, 2005 12:25 PM
website
__________ NOD32 1.1255 (20051014) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
Server Maintenance
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:01 pm
Hey Bob...how about you stay on and decipher them and I'll get off the list
!! :O))
Sent: Friday, October 21, 2005 4:25 PM
website
so
couple
Dale Fultz
Server Maintenance
Post by Dale Fultz » Sat Feb 18, 2012 2:01 pm
No Wayne, Please don't leave you have been a great help to me and I am sure
alot of other builders. I appreciate the answers and experience you pass
along . I am finally getting some where with my project and am sure I will
need you opinion again soon. Back to deburring and riveting . Later Dale
SR-033
