Prop Tach
LisaFly99
Prop Tach
Post by LisaFly99 » Fri Feb 17, 2012 10:04 pm
In a message dated 3/31/02 4:22:53 PM Central Standard Time, rebelair@idirect.com writes:
Wayne, do you know of anyone who can accurately measure my tach? If that is
right, the Sensenich folks say the prop should be 62-63 inch pitch. The
prop does measure 74" in diameter. I did purchase the prop from MAM.
BRIAN
I have a prop tach you can borrow if needed. I could ship it out tomorrow.
Phil&Lisa Smith
#460R
Brian & Pat Cross
Prop Tach
Post by Brian & Pat Cross » Fri Feb 17, 2012 10:04 pm
Hi There
That is very kind of you! I will check with our local FBO and see if they have an accurate method. Would not want to put you to such trouble.
I will keep you posted as it is an interesting problem!
Brian #328R
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of LisaFly99@aol.com
Sent: Sunday, March 31, 2002 8:12 PM
Subject: Re: Prop Tach
BRIAN
Phil&Lisa Smith
#460R
