Sensenich prop 74 x 58"
Posted: Fri Feb 17, 2012 10:04 pm
by Robert Johnson
This message is for Brian regarding your new Sensenich 74" Dia. x 58" pitch. This is what I have on Rebel "652" on my O320 H2AD 160HP. I can't pull the full 2700 RPM on a static run-up, more like 2500, but it climbs like a rocket, and just the other day, with a passenger on board and 3/4 fuel, I demonstrated to him, in level flight, fire wall the throttle, fight to stop from climbing, and watch the airspeed indicator creep past 160 mph, while approaching 2700 rpm. From what you described with your performance, it does not sound like a 58" pitch. Have you checked the markings on the hub ??
by Brian & Pat Cross
Hi Robert
Thanks very much for your info. I am going way over the engine red-line assuming my tach is correct. I am going to get my tach checked somewhere. Static rpm is at least 2500 rpm. I can go over 2700 rpm at 12,000 feet...something Sensenich thought would never happen.
I will pull the prop assembly apart this weekend & check for markings. I contacted the fine folks at Purple Hill Air who just painted the aircraft & installed the prop for & they stated that no information of any kind came with the prop save a generic prop log booklet.
Robert, you mention that the hub has the diameter & pitch marked on the hub. Is this on the front or back? I have not seen the hub as it is covered by the great looking Sensenich spinner. Getting their spinner, by the way, turned out really well. No cutting required, and the spinner is all predrilled, with nut plates, and the best part is that the material is heat treated. I would also not be inclined to use the Murphy spinner. Had some trouble with the forward flange although the rear flange with a doubler & the spinner itself looks great.
That sounds like one heck of speed for a Rebel. Have you cross checked your airspeed with GPS etc? As I mentioned earlier, I am now back at the speed of Rebel equipped with the Rotax 912. Although the 912 is a very fine engine, this is not what I am looking for.
Thanks again for your help.
Brian #328R
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Robert Johnson
Sent: Thursday, March 28, 2002 8:25 AM
Subject: Sensenich prop 74 x 58"
by Mike Kimball
Poor man's way to check the tach: Put a little piece of duct tape on the back of a prop blade, wait for the sun to do down, then position the airplane with one of the airport flood lights behind the plane. In the USA we have 60 cycles per second AC power (plus or minus no more than ~2% usually). The light will flicker at that rate even if you can't see it. (I don't know if Canada might be 50 Hz.) Set the rpm at factors of the power cycle rate. For instance, set 1800 rpm for 60 Hz power. At 1800 rpm the prop with the tape on it should appear to stop. If it stops at something other than 1800 rpm, that is how far off your tach is. If it stops at 1700 rpm, it is reading 100 rpm low. (You need the tape because most props are painted black on the back and would be harder to see.) The prop should appear to stop at all factors of 60, such as 1200 and 2400 rpm as well as 1800 rpm.
SR#044
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Brian & Pat Cross
Sent: Thursday, March 28, 2002 4:46 PM
Subject: RE: Sensenich prop 74 x 58"
Hi Robert
Brian #328R
by Legeorgen
Brian,
The prop markings for pitch, length, etc., were etched into the hub of my Sensenich prop. You can't miss them. I don't remember if it was front or back.
Bruce G 357R
Hi MIke
That is quite a thought re: RPM testing. We do indeed have the same frequency here. Though I believe the frequency spec. is much much tighter than 2%. I used to balance large fans using strobe equipment etc. to measure phase angles of the out of balance fans etc. Same principal. I could give that a try. I guess I better not try that inside with my hangar door shut if I can't wait for nightfall! (Just kidding).
Thanks for your thoughts.
Brian #328R
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Mike Kimball
Sent: Friday, March 29, 2002 10:21 PM
SR#044
Hi Robert
Brian #328R
by Bob Patterson
Hi Brian !
Sounds like you've checked everything out and the prop
IS what it's supposed to be ..... tach error is only remaining
possibility. There's likely somebody in the chapter who has
an optical tach. If you can get up earlier tomorrow night,
before the RAA meeting, we can try to catch somebody ...
Per might have one ... and he's usually there.
We'll be there by about 7 anyway, as Anna is doing the
coffee & donuts for the meetings. Call us earlier, if you want.
Would like to see the bird and talk to you anyway.
---------------------------------orig.----------------------------
At 05:21 PM 3/31/02 -0500, you wrote:
Hi MIke
Brian #328R
1800 rpm.
SR#044
Brian & Pat Cross
Hi Robert
Brian #328R
Robert Johnson
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2600.0" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><SPAN class=650074017-31032002><FONT face=Arial color=#0000ff size=2>Hi
MIke</FONT></SPAN></DIV>
size=2></FONT></SPAN>&nbsp;</DIV>
<DIV><SPAN class=650074017-31032002><FONT face=Arial color=#0000ff size=2>That
is quite a thought re: RPM testing.&nbsp; We do indeed have the same frequency
here.&nbsp; Though I believe the frequency spec. is much much tighter than
2%.&nbsp; I used to balance large fans using strobe equipment etc. to measure
phase angles of the out of balance fans etc.&nbsp; Same principal.&nbsp; I
could
give that a try.&nbsp; I guess I better not try that inside with my hangar
door
shut if I can't wait for nightfall!&nbsp; (Just kidding).</FONT></SPAN></DIV>
size=2>Thanks
for your thoughts.</FONT></SPAN></DIV>
size=2>Brian
#328R</FONT></SPAN></DIV>
<BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px">
<DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma
size=2>-----Original Message-----<BR><B>From:</B> murphy-rebel@dcsol.com
[mailto:murphy-rebel@dcsol.com]<B>On Behalf Of </B>Mike
Kimball<BR><B>Sent:</B> Friday, March 29, 2002 10:21 PM<BR><B>To:</B>
murphy-rebel@dcsol.com<BR><B>Subject:</B> RE: Sensenich prop 74 x
58"<BR><BR></FONT></DIV>
<DIV><SPAN class=390400903-30032002><FONT face=Arial color=#0000ff
size=2>Poor
man's way to check the tach:&nbsp; Put a little piece of duct tape on the
back
with
one of the airport flood lights behind the plane.&nbsp; In the USA we
have 60
usually).&nbsp; The
light will flicker at that rate even if you can't see it.&nbsp; (I don't
know
if Canada might be 50 Hz.)&nbsp; Set the rpm at factors of the power cycle
rate.&nbsp; For instance, set 1800 rpm for 60 Hz power.&nbsp; At 1800 rpm
prop with the tape on it should appear to stop.&nbsp; If it stops at
something
other than 1800 rpm, that is how far off your tach is.&nbsp; If it stops at
1700 rpm, it is reading 100 rpm&nbsp;low.&nbsp; (You need the tape because
most props are painted black on the back and would be harder to see.)&nbsp;
2400 rpm
as well as 1800 rpm.</FONT></SPAN></DIV>
size=2>Mike
Kimball</FONT></SPAN></DIV>
size=2>SR#044</FONT></SPAN></DIV>
<DIV class=OutlookMessageHeader><FONT face="Times New Roman"
[mailto:murphy-rebel@dcsol.com]<B>On Behalf Of</B> Brian & Pat
Cross<BR><B>Sent:</B> Thursday, March 28, 2002 4:46 PM<BR><B>To:</B>
<DIV><SPAN class=650492101-29032002><FONT face=Arial color=#0000ff size=2>Hi
Robert</FONT></SPAN></DIV>
size=2>Thanks very much for your info.&nbsp; I am going way over the engine
red-line assuming my tach is correct.&nbsp; I am going to get my tach
checked
somewhere.&nbsp; Static rpm is at least 2500 rpm.&nbsp; I can go over
2700 rpm
at 12,000 feet...something Sensenich thought would never happen.&nbsp;
<DIV><SPAN class=650492101-29032002><FONT face=Arial color=#0000ff size=2>I
markings.&nbsp;
kind
came with the prop save a generic prop log booklet.</FONT></SPAN></DIV>
size=2>Robert, you mention that the hub has the diameter & pitch
marked on
the hub.&nbsp; Is this on the front or back?&nbsp; I have not seen the
hub as
it is covered by the great looking Sensenich spinner.&nbsp; Getting their
spinner, by the way, turned out really well.&nbsp; No cutting required, and
material is heat treated.&nbsp; I would also not be inclined to use the
Murphy
spinner.&nbsp; Had some trouble with the forward flange although the rear
great.</FONT></SPAN></DIV>
size=2>That
sounds like one heck of speed for a Rebel.&nbsp; Have you cross checked your
airspeed with GPS etc?&nbsp; As I mentioned earlier, I am now back at the
speed of Rebel equipped with the Rotax 912.&nbsp; Although the 912 is a very
fine engine, this is not what I am looking for.</FONT></SPAN></DIV>
size=2>Thanks again for your help.</FONT></SPAN></DIV>
size=2>Brian #328R</FONT></SPAN></DIV>
[mailto:murphy-rebel@dcsol.com]<B>On Behalf Of </B>Robert
Johnson<BR><B>Sent:</B> Thursday, March 28, 2002 8:25 AM<BR><B>To:</B>
murphy-rebel@dcsol.com<BR><B>Subject:</B> Sensenich prop 74 x
<DIV><FONT size=2>This message is for Brian regarding your new
Sensenich 74"
160HP.
past 160
markings on the hub ??</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
Hi Bob
I have something on tomorrow night thanks. I will try to catch up with you.
As I stated in another email, my tach is probably not dead on, but I know I
have never had the engine running so fast. It is really easy to the engine
to red line now compared to when the Warp Drive prop was installed. Do you
think that will change with the warmer weather?
Thanks again for your thoughts Bob.
Brian #328R
Sent: Sunday, March 31, 2002 7:54 PM
Hi Brian !
Hi MIke
Brian #328R
(I
1800 rpm.
SR#044
Brian & Pat Cross
Hi Robert
doubler
fine
Brian #328R
Of
Robert Johnson
hub
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
size=2>Hi
size=2>That
frequency
measure
could
door
size=2>Thanks
size=2>Brian
size=2>Poor
back
with
have 60
usually).&nbsp; The
know
cycle
something
at
because
see.)&nbsp;
2400 rpm
size=2>Mike
size=2>Hi
engine
checked
2700 rpm
size=2>I
markings.&nbsp;
aircraft
kind
marked on
hub as
Murphy
size=2>That
your
very
Sensenich 74"
160HP.
it
throttle,
past 160
markings on the hub
by Mike Davis
Sent: Sunday, March 31, 2002 5:06 PM
Another way to test your RPM might be to use/borrow a cheap automotive diagnostic tester. I used to have one (sold it years ago in a garage sale) from Canadian Tire that had a pick-up sensor that attached to a plug wire, and you set the unit to 4, 6 or 8 cyl to get the right RPM reading for your engine. I don't see why this wouldn't work for a Lyc as well. The pick-up lead should be long enough that you could do it with the cowl attached. Of course, it will still be a little windy there, if you do a full throttle static run-up.
Real weird about your Sensenich problems. I was thinking of buying the same prop, but with the 56 inch pitch for best float performance.
Glad to hear that the Warp failure on Jack's plane was just the cracks, so I will still keep flying mine.
Good luck and keep us posted.
Sent: Sunday, March 31, 2002 2:21 PM
Hi MIke
Brian #328R
SR#044
Hi Robert
Brian #328R
by Bob Patterson
Hi Brian !
I doubt the weather will make <that> much of a difference -
there definitely is something amiss, though. An interesting problem !
Will try to track down a photo-tach tonight - I'm sure
somebody in the chapter has one ...
....bobp
-------------------------------------orig.------------------------------
At 11:28 PM 3/31/02 -0500, you wrote:
Hi Bob
Brian #328R
Hi Brian !
Hi MIke
Brian #328R
(I
1800 rpm.
SR#044
Brian & Pat Cross
Hi Robert
doubler
fine
Brian #328R
Of
Robert Johnson
hub
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
size=2>Hi
size=2>That
frequency
measure
could
door
size=2>Thanks
size=2>Brian
size=2>Poor
back
with
have 60
usually).&nbsp; The
know
cycle
something
at
because
see.)&nbsp;
2400 rpm
size=2>Mike
size=2>Hi
engine
checked
2700 rpm
size=2>I
markings.&nbsp;
aircraft
kind
marked on
hub as
Murphy
size=2>That
your
very
Sensenich 74"
160HP.
it
throttle,
past 160
markings on the hub
by Walter Klatt
Hi MIke
Brian #328R
SR#044
Hi Robert
Brian #328R
