SR - Fus/stab attach bracket bolts and Fin/Stab hinge bushin
Posted: Sat Feb 18, 2012 12:59 am
Hello again SR'ers.
It does say in the manual to use 1/4" bolts. Manual dated 21/06/99 Step 98:
"Bolt the two Fus-370 front stab mounts and two Fus-371 rear stab mounts in
plane with the AN4 bolts. The rear mounts ---------------"
It does not, unfortunately, tell you to drill them to a 1/4" at any point
before hand.
As for the hinges on the Fin and Stab, I did in fact ream them out and
install "hat" bushings today. I just happened to have the 8 bushings
required in my surplus stuff, no less/no more just enough to do the job. The
ones I used are 1/4" ID x 3/8" O.D with a 1/2" diameter flange that is .059
thick. Overall width is .322, which left just over 1/4" on the 3/8" diameter
(which nicely matches the hinge width). The flange will also work as my
thrust face so two things licked at once. Bushings should be easy to get
from any machinery supply outlet and/or various other places.
*******Please don't try this yourself unless you have the proper straight
reamers to match the bushing O.D, so once you put a coat of chromate on the
area and press it in, it will stay there and not spin.******
**Posted two pictures to SR - Tail Feathers section. A little flash
"washed", but you can tell what they are!
Once again I must also state that the above is just my personal adlib on
building this thing. The final decision to do similar rests totally with
you!
Sent: Wednesday, March 13, 2002 11:23 PM
Subject: Re: Anchor Nut & Another Option
before hand.
you!
bolts,Don and all SR'ers.
I almost bolted the stab attach brackets into the tail cone with 3/16
meon initial assembly, and then realized that the slots in the rear set are
1/4" wide. Somewhere in the manual it tells you to use 1/4" bolts and I
<think> I read somewhere that you had to drill them to 1/4" to put those
1/4" bolts in!!
As for the Proseal, I think this is just Brian G's sealer of choice. Back
when I discussed the necessity of the Rebel tail post SB with him he told
asthat he liked to put the tail section of the Rebel together with proseal
EP420well. It will definitely seal out water as well if not better than the
of(or your corrosion proofer of choice) and of course it does a better job
they"gluing" everything together to stop things (like rivets) from "working".
I'll make up my mind, on what to use, the morning I finally get to it!
Now you post a great idea like that! Will be great if you ever have to
change the hinges from wear. It will happen with the bolt just riding on
aluminium. The big thing is to make sure when you put the bolts in that
andare tight so they don't rotate in the rudder/elevator hinges. This will
leave only the fin/stab hinges to wear which are easy to get at and hone
others.insert bushings into when the time comes (or I might just do that now!).
That way you may never need to take the hinges off, but I like your wire
idea. Haven't closed the stab so not too late for me there. Will have to
have a look and see what I have for bolts, or start drilling some. The fin
is too late and I'm not going to open it back up.
The drilled head bolts should have the same tension strength as the
VERYJust think prop bolts have a hole through the head and heck a "real" prop
bollt AN73 has 3 holes drilled through the head!!!
If you want some anchors contact me off line!
Sent: Wednesday, March 13, 2002 9:58 PM
Subject: Anchor Nut & Another Option
thatHi Wayne,
Good luck with your off loading Chinese Fire Drill. We where fortunateAerocet did a great job of crating. 40"X40"x22' , built very well and
totheHEAVY.
You mentioned the close of your tail feathers. MAM recommends installingexternal doublers using proseal. When we contacted the manufacturer, to
order, they indicated that proseal for fuel was not there best product
(productprevent corrosion between layers. We used the "corrosion proseal"
lapsnumber in the shop I can forward it if you want) It was brushable and
similar to the fuel brushable proseal. We used in between all the large
doublers and skin in the upgrade. We also used it for skin structure
areinthe tail feathers. (built from kit).
I felt the same way about the K2000's that's why I asked.
The anchor nuts ... you mention 1/4 x 28. Our Horizontal bracket bolts
say3/16. ??????
You know Wayne, it wasn't so much the $24, a drop in the OCEAN as they
3/16.when it comes to the cost of this project. I think it was the idea of
spending $3 on a 3/16 nut.
Anyway, I'd rather give you the $16 bucks + postage than the Big ACS.
BUT, do you think it is necessary to go 1/4" bolts when MAM supplied
inat(more bolts to order)
Will wait for your response before making a decision on bolt size.
On another matter.
To prevent hinge bolts from spinning in the event we needed to re-torquethea future time or replace the various control hinges we used bolts with
drilled heads on the inside of the structure and used stiff wire to pintwo heads together to prevent head rotation. Worked fine.
Question, do you know if the drilled head bolts have the same strength
****tension as undrilled.?
Don Boardman
& Partner
Randy Bowers
SR3500#130 "The Muskie" M-14PF Aerocet 3400 amphibs, Rome, NY
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
