Prosealed seams
LisaFly99
Prosealed seams
Post by LisaFly99 » Fri Feb 17, 2012 9:59 pm
In a message dated 3/13/02 10:26:38 PM Central Standard Time, oifa@irishfield.on.ca writes:
As for the Proseal, I think this is just Brian G's sealer of choice. Back
when I discussed the necessity of the Rebel tail post SB with him he told me
that he liked to put the tail section of the Rebel together with proseal as
well. It will definitely seal out water as well if not better than the EP420
(or your corrosion proofer of choice) and of course it does a better job of
"gluing" everything together to stop things (like rivets) from "working".
WAYNE
RUMMER has it that when the BD5 fuselage was being developed it was put together with Proseal, then the rivets where drilled out, the fuselage was put on a paint shaker for so long and the seams held tight.
Phil&Lisa Smith
Peter Cowan/Lexi Cameron
Prosealed seams
Post by Peter Cowan/Lexi Cameron » Fri Feb 17, 2012 9:59 pm
WAYNE
Phil&Lisa Smith Would using it mean that doing a repair would cause damage in getting things apart?Peter
LisaFly99
Prosealed seams
In a message dated 3/14/02 9:56:38 AM Central Standard Time, cowcam@pipcom.com writes:
VERY likely, And a good point.
Phil&Lisa Smith
RJ Thomas
Prosealed seams
Post by RJ Thomas » Fri Feb 17, 2012 9:59 pm
Peter,
I had to pull some doublers off of the rear spar to accommodate new doublers for the 3500 upgrade on an SR. The spars were OK when I finished, but the old doublers were trashed. I don't believe I could have "saved" the parts even if I had tried.
Conversely, I rather stupidly installed the fuel tank access doublers on the bottom tank skin before installing the tank skin on the wing. I quickly discovered that my arms are not sufficiently articulated to allow for remedial ProSeal work through those doublers. Pulling the ProSeal'd doublers was a chore but was accomplished without the destruction of any parts.
I think it rather depends on the application, thin sheet and/or curves raise the risk factor considerably.
Cheers, rj
R J Thomas
Lafayette, LA
Super Rebel 3500 N140SR
From: Peter Cowan/Lexi Cameron [mailto:cowcam@pipcom.com]
Sent: Thursday, March 14, 2002 9:58 AM
Subject: Re: Prosealed seams
WAYNE
Phil&Lisa Smith
Peter
Prosealed seams
Thanks for your experiences. I've often thought it is tempting to put something like proseal or 3M 5000 (or similer products) in float seams but the thought of doing a repair scares me.
Peter.
Peter,
Cheers, rj
R J Thomas
Lafayette, LA
WAYNE
Phil&Lisa Smith
Peter
George Coy
Prosealed seams
Post by George Coy » Fri Feb 17, 2012 9:59 pm
Tis true. There is a BD 5 slowly going together here at our airport and that is the process used. George Coy
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of LisaFly99@aol.com
Sent: Thursday, March 14, 2002 10:38 AM
WAYNE
Phil&Lisa Smith
Prosealed seams
Post by Bob Patterson » Fri Feb 17, 2012 9:59 pm
Hi Peter !
Using ProSeal or SikaFlex in the seams on floats is S.O.P. -
it's part of the Murphy float instructions. You really have to
use something like that to stop leaks ....
....bobp
----------------------------------orig.-------------------------------
Peter.
Peter,
Cheers, rj
R J Thomas
Lafayette, LA
choice. Back
he told me
proseal as
the EP420
better job of
"working".
WAYNE
Phil&Lisa Smith
Peter
<HTML>
<HEAD>
<META content=text/html;charset=iso-8859-1
http-equiv=Content-Type><!DOCTYPE HTML PUBLIC "-//W3C//DTD W3 HTML//EN">
<META content='"MSHTML 4.72.3110.7"' name=GENERATOR>
<STYLE>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</STYLE>
</HEAD>
<BODY bgColor=white lang=EN-US link=blue vLink=purple>
<DIV><FONT color=#000000 face="Bookman Old Style">Thanks for your experiences.
me.</FONT></DIV>
<DIV><FONT color=#000000 face="Bookman Old Style"></FONT><FONT
face="Bookman Old Style">Peter.</FONT></DIV>
<BLOCKQUOTE
style="BORDER-LEFT: #000000 solid 2px; MARGIN-LEFT: 5px; PADDING-LEFT: 5px">
<DIV><FONT face=Arial size=2><BR>&nbsp;</DIV></FONT>
<DIV class=Section1>
<P class=MsoNormal><FONT color=navy face=Arial size=2><SPAN
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE:
10pt">Peter,</SPAN></FONT></P>
10pt">&nbsp;</SPAN></FONT></P>
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">I had to pull
some
upgrade on an SR.&nbsp;&nbsp; The spars were OK when I finished, but
the old
doublers were trashed.&nbsp;&nbsp; I don't believe I could have
"saved" the parts even if I had tried.</SPAN></FONT></P>
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">Conversely, I
skin before installing the tank skin on the wing.&nbsp; I quickly
discovered
ProSeal
work through those doublers.&nbsp; Pulling the ProSeal'd doublers was a
</SPAN></FONT></P>
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">I think it rather
considerably.</SPAN></FONT></P>
10pt">Cheers,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb
sp;&nbsp;
rj</SPAN></FONT></P>
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">R J
Thomas</SPAN></FONT></P>
10pt">Lafayette</SPAN></FONT><FONT
10pt">,&nbsp;&nbsp;&nbsp;&nbsp;
</SPAN></FONT><FONT color=navy face=Arial size=2><SPAN
10pt">LA</SPAN></FONT></P>
style="COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">Super Rebel
3500&nbsp; N140SR</SPAN></FONT></P>
10pt">+++++++++++++++++++++++++</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN-LEFT: 0.5in"><FONT face=Tahoma
size=2><SPAN
style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">-----Original
Message-----<BR><B><SPAN style="FONT-WEIGHT: bold">From:</SPAN></B> Peter
Cowan/Lexi Cameron [mailto:cowcam@pipcom.com] <BR><B><SPAN
style="FONT-WEIGHT: bold">Sent:</SPAN></B> Thursday, March 14, 2002 9:58
AM<BR><B><SPAN style="FONT-WEIGHT: bold">To:</SPAN></B>
murphy-rebel@dcsol.com<BR><B><SPAN
style="FONT-WEIGHT: bold">Subject:</SPAN></B> Re: Prosealed
seams</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN-LEFT: 0.5in"><FONT face="Times New Roman"
size=3><SPAN style="FONT-SIZE: 12pt">&nbsp;</SPAN></FONT></P>
<BLOCKQUOTE
style="BORDER-BOTTOM: medium none; BORDER-LEFT: black solid 1.5pt;
BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN-BOTTOM: 5pt;
MARGIN-LEFT: 3.75pt; MARGIN-TOP: 5pt; PADDING-BOTTOM: 0in; PADDING-LEFT:
4pt; PADDING-RIGHT: 0in; PADDING-TOP: 0in">
<P class=MsoNormal style="MARGIN-LEFT: 0.5in"><FONT face=Arial
size=2><SPAN
style="FONT-FAMILY: Arial; FONT-SIZE:
10pt"><BR><BR><BR></SPAN></FONT></P>
size=2><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">As for
the&nbsp; Proseal, I think this is just Brian G's sealer of choice.
Back<BR>when I discussed the necessity of the Rebel tail post SB with
him he told me<BR>that he liked to put the tail section of the Rebel
together with proseal as<BR>well. It will definitely seal out water as
well if not better than the EP420<BR>(or your corrosion proofer of
choice) and of course it does a better job of<BR>"gluing"
"working".</SPAN></FONT></P>
size=2><SPAN
style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><BR><BR>WAYNE<BR>RUMMER
has
put on
a paint shaker for so long and the seams held tight.<BR>Phil&Lisa
Smith</SPAN></FONT><FONT face=Arial><SPAN style="FONT-FAMILY: Arial">
</SPAN></FONT></P></BLOCKQUOTE>
<BLOCKQUOTE
size=3><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 12pt">Would
using it
apart?</SPAN></FONT></P></BLOCKQUOTE>
<BLOCKQUOTE
size=3><SPAN
12pt">Peter</SPAN></FONT></P></BLOCKQUOTE></DIV></BLOCKQUOTE></BODY></HTML>
Prosealed seams
Bob two questions:
What is "SOP"?
Is Proseal equivalent to sikoflex in sticking capability?
The zinc chromate tape that used to be used in float seams sealed but didn't
bond so that dissasssembly wasn't a big problem.
Peter
Hi Peter !
....bobp
Peter.
Peter,
finished,
parts.
Cheers, rj
R J Thomas
Lafayette, LA
choice. Back
he told me
proseal as
the EP420
better job of
"working".
WAYNE
was
Phil&Lisa Smith
Peter
<HTML>
<HEAD>
<STYLE>
@font-face
{margin:0in;
font-size:12.0pt;
{color:blue;
{color:purple;
span.EmailStyle17
{font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
div.Section1
{page:Section1;}
</STYLE>
</HEAD>
experiences.
(or
me.</FONT></DIV>
<BLOCKQUOTE
5px">
some
the old
tank
discovered
ProSeal
</SPAN></FONT></P>
rather
factor
b
sp;&nbsp;
size=2><SPAN
Peter
9:58
Roman"
<BLOCKQUOTE
size=2><SPAN
choice.
with
Rebel
water as
of<BR>"gluing"
size=2><SPAN
has
together
put on
tight.<BR>Phil&Lisa
Arial">
<BLOCKQUOTE
using it
<BLOCKQUOTE
size=3><SPAN
Prosealed seams
Standard Operating Procedure .....
SikaFlex is pretty much equivalent to ProSeal EXCEPT:
- SikaFlex comes in setting times from 2 hr., 4 hr., 8 hr., 12 hr., and 24 hr.
(makes it a lot more flexible for working time ..)
- SikaFlex is NOT fuelproof ! Good for floats, but not gas tanks !
The EPA have pretty much made zinc chromate disappear - at least
in North America ..
...bobp
------------------------------------orig.--------------------------------
At 08:07 AM 3/15/02 -0500, you wrote:
Bob two questions:
What is "SOP"?
Peter
Hi Peter !
....bobp
Peter.
Peter,
finished,
parts.
Cheers, rj
R J Thomas
Lafayette, LA
choice. Back
he told me
proseal as
the EP420
better job of
"working".
WAYNE
was
Phil&Lisa Smith
Peter
<HTML>
<HEAD>
<STYLE>
@font-face
{margin:0in;
font-size:12.0pt;
{color:blue;
{color:purple;
span.EmailStyle17
{font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
div.Section1
{page:Section1;}
</STYLE>
</HEAD>
experiences.
(or
me.</FONT></DIV>
<BLOCKQUOTE
5px">
some
the old
tank
discovered
ProSeal
</SPAN></FONT></P>
rather
factor
b
sp;&nbsp;
size=2><SPAN
Peter
9:58
Roman"
<BLOCKQUOTE
size=2><SPAN
choice.
with
Rebel
water as
of<BR>"gluing"
size=2><SPAN
has
together
put on
tight.<BR>Phil&Lisa
Arial">
<BLOCKQUOTE
using it
<BLOCKQUOTE
size=3><SPAN
klehman
Prosealed seams
Post by klehman » Fri Feb 17, 2012 9:59 pm
FWIW the MSDS sheet says the Sikoflex 1A is a moderate health hazard,
contains xylene and benzene, and prolonged and/or repeated contact with
skin may cause an allergic reaction/sensitization. Don't have a clue how
significant this is but the sensitization thing caught my eye on a one
part curing polyurethane.
I didn't think that pro-seal was all that bad other than containing
toluene and requiring ventilation and gloves, but darned if I can locate
an MSDS sheet for comparison.
http://www.sikacanada.com/eng/constr/cat/js/d100.htm also hints that a
primer might be beneficial for items that are going to be immersed in
water??
24 hr.
in North America ..
