Al & Deb Paxhia's 3500
Posted: Sat Feb 18, 2012 12:47 am
"She" sure looks close to completion Al!!!! Can smell that engine running
already!
Sent: Friday, February 08, 2002 7:32 PM
Subject: Re: SR3500 - Fus705 to 310 bolts and float attachment
already!
IfMike,
I have uploaded a photo in the SR fuselage section, the only one handy.
upgradeyou look close you can see the belly wrap and float brackets.
Al
Sent: Thursday, February 07, 2002 10:39 PM
now.This sounds like a good candidate for a photo to be uploaded. I for one
would like to see how/where you cut your slots. I for one think the
prototype looks like it's got a big hole in the side the way it is doneMike
195SR
Sent: Thursday, February 07, 2002 7:55 PM
Hi Wayne,
The wrap for the belly (don't have the part # handy) on the 3500
threetightiscut in half for installation. I had Murphy roll the part so it fitstothe sill. Also when cutting the gear leg slot and FL400's we made
boltsMurphyslots, two for the float attach brackets and one for the gear leg.thelikeused a large rectangle that when it pulled up around the sill is looksit gaps and bends rather sharp. Rolling eliminates the fit problem andtheslots look clean enough that I don't need a cover over the gear leg ordrilledfloat brackets.
Al
MOOOOSE#26
Sent: Thursday, February 07, 2002 4:54 PM
Subject: SR3500 - Fus705 to 310 bolts and float attachment
with
isinexact
slipjust
pilotback
forhole.
byboltbeforetriangleI
itselflater.whileanyonesoI**
http://rebel:builder@www.dcsol.com:81/default.htmhttp://rebel:builder@www.dcsol.com:81/default.htm******** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself** Archives located at
********** To contact the list admin, e-mail mike.davis@dcsol.com
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
