Wing wiring and a strobe question
Posted: Sat Feb 18, 2012 12:47 am
I am thinking about running the wires for lights and pitot heat down the
inside of the rear door posts. Is this a bad idea with my fuel lines in
there as well? The fuel lines are solid aluminum tubing and I was planning
on a non-metal conduit for the wires. Pitot tubing would be in there on one
side as well. Entry would be through the fuselage rib in front of the rear
door post, then angled inside the upper, rear corner sections of the door
frame, then through the door post bulkhead (hidden from view inside the
corner section).
Anyone know the pros and cons of using wingtip mounted strobe power supplies
versus a remote mounted supply? I already know that the remote supply
requires 3-conductor high voltage lines to be run all the way out to each
wing tip, versus 1-conductor, 18-gauge, low voltage wire for the wing tip
mounted supplies. Also, one remote supply is cheaper than two wingtip
mounted ones. Wires for a remote supply are already in the wings. Does the
remote supply and long runs of high voltage increase problems with radio
interference? Maybe one other con to the high voltage run if those wires
are near the fuel lines. A high voltage spark near the fuel would be worse
than a low voltage spark I would imagine. Maybe I've already convinced
myself to switch to low voltage lines and wingtip mounted power supplies
despite the expense in time and money.
SR #044
P.S. While installing the aileron cables through the front door post I
tried someone's suggestion of using the kit supplied cable fairleads that
have the mounting holes perpendicular to the cable hole, drilling another
cable hole parallel with the mounting holes, and it worked great. I was
even able to slightly angle the hole I drilled to line up better with the
actual angle of the cable. I mounted one of the fairleads backwards in the
slot in the front door post channel after filing an angle on the mounting
flanges to match the cable angle and using the original cable hole in the
fairlead.
corner section).
SR #044
fairlead.
