SR Running Cables in the Tailcone
Posted: Sat Feb 18, 2012 12:39 am
Hi Guys,
I have the Flap cable figured out.
I have the Rudder and Aileron cables figured out to the rear of the baggage
area and understand the function of the Aileron pulleys and basically where
both sets of cables end up at the tail end.
MAM says under CONTROL RIGGING, "NOTE: You will need to make and install a
channel to support the cables running down your Tailcone. Make the channel
the same length as the width of the midpoint bulkhead. Place and rivet the
channel to the bulkhead after installing the cables."
Question:
1. Can any one clarify how the rudder cables are routed between the baggage
area bulkhead and the very aft bulkhead of the tailcone?
2. Can anyone give me a better picture of what MAM is talking about in
referring to "channels to support the cables" sounds like I need to build a
version of the SkyWay?
Posting a couple of pictures would be worth a thousand words.
Thanks in advance,
Don Boardman
& Partner
Randy Bowers
SR130 Rome, NY
Question:
Thanks in advance,
Don Boardman
& Partner
Randy Bowers
SR130 Rome, NY
