Uploads/files
Posted: Sat Feb 18, 2012 12:38 am
by Mike Davis
Hi Jim, I'm sending this to the list because this is a good question that I
don't think I have ever addressed. When uploading files and entering
descriptions these are the limits imposed.
The "Description" or short description can be up to 76 characters long and
is displayed in the normal file listing.
The "Long Description" can contain up to 15 lines of text with up to 80
characters on each line. The long description is displayed when you click
on "Desc" in the "Info" column of the file listing. If there is no long
description available the "Info" column will have "Info" instead of "Desc".
Your best bet when entering a truly long description is not to use the
return/enter key... just keep typing. If you enter 10 characters on a line
and hit return, you just lost 70 characters of space.
To: <mike.davis@dcsol.com>
Sent: Thursday, January 17, 2002 7:52 PM
Subject: Uploads/files
Hi Mike
Is there a character limit in the "Long description" box. I got "sniped"
in mid-sentence. It looks like a pretty big box with lots of space.
Jim R254
Uploads/files
Mike, My long descriptions always have been snipped off and I never hit the
return key!
The one I just did yesterday on the heated pitot for example, that snipped
right in the middle of the word inspection.
Cc: <murphy-rebel@dcsol.com>
Sent: Friday, January 18, 2002 1:05 AM
Subject: Re: Uploads/files
"Desc".
line
Hi Mike
in
Jim R254
Uploads/files
by Mike Davis
Well you got me Wayne... the documentation said that the long description
would take 15 lines of 80 characters each. I duplicated the problem you had
below and in both my tests, and your heated pitot example the character
count including spaces was 256... a magic number with computers... that's 32
bits (if anyone cares).
After several experiments I found that upon hitting 256 characters without a
return it cuts it off. Putting in a return every 255 characters only
allowed me 15 lines. The 255 character entries between returns were
automatically line wrapped to lines of 80 characters or less.
So... what this all means is that we've found one more limitation that I
wasn't aware of and that is not documented. You will only get 15 lines of
up to 80 characters each, but you only get 256 characters between each
return and 15 x 80 is 1200... so there will have to be some returns in
there.
Putting it to practice... I'd never expect anyone to sit and count there
characters, but at 80 characters a line, 3 lines will give you 240
characters (remember it auto wraps). So if you hit return at the end of
every 3rd line you should be able to get a full 15 lines of text in there.
I know that's a real hassle, but if you've got something you need to say,
that should get it done for you.
Sent: Friday, January 18, 2002 5:18 AM
return key!
that
click
"Desc".
line
Hi Mike
"sniped"
in
Jim R254
Uploads/files
OKAY, WILL GIVE IT A TRY ON THE NEXT ONE!
Sent: Friday, January 18, 2002 10:15 AM
had
32
there.
return key!
snipped
that
80
click
long
"Desc".
line
"sniped"
in ** To unsubscribe, send e-mail to list-server@dcsol.com with
** Archives located at
Uploads/files
by Mike Davis
Yeah... duh! What can I say, I wrote without thinking it through all the
way. I'm so used to working with network addresses that are 32 bits... four
8 bits words... each word 0-255... I saw 256 and 32 just popped into my
head.
I guess as long as we know how to get around it the clarity of my thought
process isn't to critical! :-)
I care, but...
8 bits = 2^8 = 256
16 bits = 2^16 = 65,536
32 bits = 2^32 = 4,294,967,296
:o)
;o)
Uploads/files
by Dave Klimas
I care, but...
8 bits = 2^8 = 256
:o)
;o)
