Received: from [137.186.226.180] (helo=ms01-151.tor.istar.ca)
for murphy-rebel@dcsol.com
id 0zXdTA-0006Bq-00; Sun, 25 Oct 1998 22:37:25 -0500
Mime-Version: 1.0
Subject: tailsprings
Message-Id: <E0zXdTA-0006Bq-00@mail2.toronto.istar.net>
Date: Sun, 25 Oct 1998 22:37:25 -0500
Brian,
Just hobbled up out of the basement - BOTH of my metal
tailsprings are 1 5/8" wide - the OLD composite was 1 3/4" !!
All are 16 1/2" long.
It looks like your best bet is to use the composite one,
perhaps a little shorter if necessary.
....bobp
tailsprings
tailsprings
Received: from RebelAir@aol.com
by imo24.mx.aol.com (IMOv16.10) id EKGVa02343
for <murphy-rebel@dcsol.com>; Mon, 26 Oct 1998 23:54:05 +1900 (EST)
Message-ID: <71751914.363551ed@aol.com>
Date: Mon, 26 Oct 1998 23:54:05 EST
Mime-Version: 1.0
Subject: Re: tailsprings
X-Mailer: Windows AOL sub 19
Hi Bob
Thanks again for your help. I think you are right, I will stick with the
composite as you think that the failure mode is not catastrophic. If it
gradually delaminates as you suggest, I can catch it during my preflights.
I will just have to be more careful about my landings - ie make them smooth!
Best Regards
Brian
Mime-Version: 1.0
Hi Bob
Best Regards
Brian
tailsprings
Received: from [137.186.224.99] (helo=ms01-99.tor.istar.ca)
id 0zYEBv-0006Zz-00; Tue, 27 Oct 1998 13:50:04 -0500
Mime-Version: 1.0
Message-Id: <E0zYEBv-0006Zz-00@mail2.toronto.istar.net>
Date: Tue, 27 Oct 1998 13:50:04 -0500
Not likely a big problem !!! :-)
....bobp
----------------------------orig.----------------------------------------
Mime-Version: 1.0
....bobp
smooth!Hi Bob
Best Regards
Brian
tailsprings
by imo15.mx.aol.com (IMOv16.10) id ECYJa02538
for <murphy-rebel@dcsol.com>; Wed, 28 Oct 1998 22:26:58 +1900 (EST)
Message-ID: <91ff8b9f.3637e082@aol.com>
Date: Wed, 28 Oct 1998 22:26:58 EST
Mime-Version: 1.0
Hi Bob
I assume you were talking about my landings. Thanks for your encouragement.
The Super Cub, (my favourite airplane to date), taught me alot about flying
and really helped my landings. I also found out what the rudder was for. I
got my private license and only used it a few times in the 172!
Best Regards
Brian #328
Mime-Version: 1.0
Hi Bob
Best Regards
Brian #328
tailsprings
Received: from [137.186.228.121] (helo=ms02-375.tor.istar.ca)
id 0zYwlj-0004rq-00; Thu, 29 Oct 1998 13:25:59 -0500
Mime-Version: 1.0
Message-Id: <E0zYwlj-0004rq-00@mail2.toronto.istar.net>
Date: Thu, 29 Oct 1998 13:25:59 -0500
I was ! It is MUCH easier to get good landings in the Rebel than
in the Super Cub !! If you aren't at just the right attitude at just the
right speed, the Cub will SKIP ... The Rebel just lands & stays put.
-----------------------------------orig.---------------------------------
Mime-Version: 1.0
encouragement.Hi Bob
IThe Super Cub, (my favourite airplane to date), taught me alot about flying
Best Regards
Brian #328
tailsprings
Received: from tim - 208.251.189.212 by email.msn.com with Microsoft
SMTPSVC;
Mon, 2 Nov 1998 15:52:08 -0800
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: tailsprings
Date: Mon, 2 Nov 1998 15:03:24 -0800
Message-ID: <001201be06ba$500151a0$2a640a80@tim>
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Importance: Normal
In-Reply-To: <E0zYwlj-0004rq-00@mail2.toronto.istar.net>
Return-Path: tlcarter@email.msn.com
Bob,
Are you running bungee gear? If so, do you have problems with the bolts
bending?
Also, I received an "AD" from MAM (about 18 mos. back) regarding a new way
to route the safety cable running thru the bungee gear legs. At the risk of
appearing like I can't follow directions, I can't follow those directions or
get a mental image of exactly what they are saying about using one
continuous loop. Are you familiar with this?
Finally, there is someone in Canada who makes a steel bushing block for the
tops of the main gear legs, so that the bearing is not steel AN bolt to
aluminum gear leg. Are you familiar with the mod, and if so, would you
recommend it?
Tim C
#438R
Sent: Thursday, October 29, 1998 10:26 AM
To: Murphy Rebel
SMTPSVC;
MIME-Version: 1.0
Importance: Normal
Bob,
bending?
recommend it?
Tim C
#438R
To: Murphy Rebel
Best Regards
Brian #328
