I had the same problem.. Then I noticed that Murphy had taken these sameThe only fairleads I was provided with my kit require that an angle be mounted
at
each location since they mount 90 degrees to the cable. I would much rather
have the fairlead mount right on the same surface as the hole and the
plastic rings are easy.
fairleads on the factory plane, and drilled a new hole perpendicular to the
original center hole.. Seems a little odd, but it works..
#057SR
