SR3500 - Rudder Pedal Assembly
Posted: Sat Feb 18, 2012 12:37 am
I used a long drill bit mounted in the drill press. I clamped the tube to
the table and rotated it 90degrees. It was a slow process chipping out the
weld.
Sent: Wednesday, January 02, 2002 9:28 PM
Subject: SR3500 - Rudder Pedal Assembly
weld.
tubeThe rudder pedal assembly has welded fittings that seem to prevent slave
tofrom properly sliding into tube - How does one ream or clean out the welds
**allow the tubes (RP18) to slide nicely in the CC102 Tubes?
