by www.az.com (8.8.8/8.8.
Thu, 22 Oct 1998 12:43:52 -0700 (PDT)
(envelope-from morehous@az.com)
Message-ID: <362F294D.4959EC8@az.com>
Date: Thu, 22 Oct 1998 12:47:13 +0000
X-Mailer: Mozilla 4.5 (Macintosh; I; PPC)
X-Accept-Language: en
MIME-Version: 1.0
To: "Murphy-Rebel@dcsol.com" <Murphy-Rebel@dcsol.com>,
Charles Bailey <baileyca@gte.net>
Subject: corrosion proofing
Content-Type: text/plain; charset=us-ascii; x-mac-type="54455854";
x-mac-creator="4D4F5353"
Thanks for the info about front bottom
cabin floor orientation, although I
couldn't easily open your pic (not sure
why. I can read jpg's. Netscape usually
does it, and I also have a third party
graphic converter; neither worked).
I'd like to get some feedback on
corrosion proofing again. I understand I
can do it several different ways. I'd
like to some different ideas on this,
especially those related to operating
near salt water.
What I've done is treat just the mating
surfaces so far with a couple different
chromating type primers. The method I've
used for the most recent one
(PolyFiber's white stuff) is to alodyne,
then prime with a tack coat and two more
heavier coats, let dry and rivet.
I'm concerned about cost, weight, and
time if I were to treat all the
non-mating inside surfaces.
Look forward to your comments,
Dan Morehouse
R280
