Hi Rick !
The extra, staggered row of 1/8" rivets down the door post is
probably well worth the effort now, rather than the pain later.
A doubler of FUS-30 made of .032 6061 T-6 should be more than
adequate. Be sure to rivet to the horizontal bulkhead next to the
stabilizer at the top, as well as up the rudder post, and at several
places over the cone. It is important to use lots of Polyfiber Epoxy
primer between the 2 pieces, to help bond them together, as well as
prevent water from getting in there. We've been recommending this
doubler since the first Rebel was completed in Ontario - they ALL
need it !
Hope those ferocious fires we're seeing on TV are well away
from where you are !
....bobp
------------------------------orig.----------------------------------------
At 05:07 PM 12/20/01 +1100, you wrote:
G'day Wayne !....(and a Very Merry Christmas & New year to you and the
"tribe" as well ! :-)
I have just read with great interest , THIS e-mail stating to "double row
and stagger" the rivets up the door post
/ hinge as this is "standard practice since '96 "....Got to admit , I
hadn't heard of it either ! :-(......I'll have a sticky at the plane whilst
I'm out there tomorrow (it lives a bit over an hours drive away from home )
I have a single row of 1/8" rivets down that joint (as per the plans...as I
have not been told any different)....should I
1) Replace them all with 3/16" ?
OR
2) ADD another row,(of 1/8" rivets) staggered to the first ?
Also, I just noticed today, some small cracks at the bottom of the tailcone
(down below the bottom Rudder
pivot)...... ( I have 85 hours to date and 169 landings), ...I know that
there has been some talk of this area having a "doubler skin" fitted....but
I was hoping to "get away with not having to do it" as I fitted a real
SPRING on the tailwheel...which has lots of "give" and allows the tail of
the plane to move around "a bit"...NOT like the solid / unmovable hunk of
aluminium that was supplied with the kit.
Should I fabricate a doubler from .032" 6061 T6.....or thicker....and / or
from something stronger , say 2024 T3
(and what do I do with the small cracks already in the tailcone... (about
3/8" long), apart from stop drilling them ?)
Any help will be gratefully received
Rick & Wendy in OZ
541R
To:
murphy-rebel@dcsol.com
Sent: Thursday, 27 December 2001 15:15
Subject: Re: Firewall position
Well Peter! There is the double pitched row of rivets up the forward door
post (with the top 3 or 4's pitch left as is but upsized to 3/16") that I
have recommended since the winter of 1996 FOR ANY ENGINE INSTALLATION (well
before MAM put out the "float fix" bulletin after a couple aircraft,
including the factory Elite, were damaged at Osh and something had to be
done officially then). I can show you the pictures of why I started doing
this in 1996, next time you are over, but I'm not going to post them! Lets
just say that the original rivet pitch (with an O-235 engine) didn't hold up
to one ski, 2 G landings on ice!!!! Like I keep telling you guys/gals I am
rarely offering "theory" and/or calculated loads. I am passing on specific
things that I've found necessary, to keep the thing together, from proven
"destructive testing". In support of MAM, for their lack of offerings on
some of the stuff that has been found necessary to reinforce the Rebel over
the years, MAM doesn't hold onto their airplanes long enough to see most of
this and I have yet to see Robin screw up a landing either!!!!
I really don't buy the "shorten the moment arm to reduce the loads on the
cabin structure" bull. If the O-235 was supposed to be fine at the original
engine position, the O-320 isn't going to make a big difference. The weight
difference in engines is only about 30 pounds. If we were talking moving the
engine in a foot maybe, but not 3 inches.
In a (-)2.5 G (ouch!) landing that is only 75 pounds extra load (less
than one extra RV1410 rivets shear strength). I am not going to try to
figure out the load values difference on the rivets at the top of the door
post by moving the engine in 3" to 36.5", from the original 39.5", but will
only say it's not going to make a big difference structurally (changes c of
g significantly, but not load on door post rivets that are in "shear"). If
you have added the float fix doubler at the top of the post, or have done
the double staggered row of rivets up the door post (so the "guillotine"
effect can't get started at the top of the door post and shear all the
rivets out right down to the wing strut attach fitting!) you will be fine. I
can state this with confidence only because I have tried the same "testing"
on my Rebel, with the extra rivets up the door post and an O-320 engine, and
have determined that this type of "landing" is now a NDT (non-destructive
test) instead!!!
'night,
To:
Sent: Wednesday, December 26, 2001 9:49 PM
Subject: Firewall position
In scanning the manual (from early 90s) I see a comment that has not
been mentioned that I can recall about the reason for moving the firewall
back for the heavier engine. The reason stated is to shorten the moment arm
to reduce loads on the cabin structure.
Wayne, I don't recall you mentioning any reinforcements that
specifically address this aspect. Have I missed something?
Peter.
<HTML><HEAD>
<META content="text/html; charset=iso-8859-5" http-equiv=Content-Type>
<META content="MSHTML 5.00.2314.1000" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT size=2>G'day Wayne !....(and a Very Merry Christmas & New
year to
you and the "tribe" as well ! :-)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>I have just read with great interest , THIS e-mail
stating to
"double row and stagger" the rivets up the door post</FONT></DIV>
<DIV><FONT size=2>/ hinge as this is "standard practice since '96 "....Got to
admit , I hadn't heard of it either ! :-(......I'll have a sticky at the plane
whilst I'm out there tomorrow (it lives a bit over an hours drive away from
home
)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>I have a single row of 1/8" rivets down that joint (as
per the
plans...as I have not been told any different)....should I </FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>1) Replace them all with 3/16" ?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>OR</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>2) ADD another row,(of 1/8" rivets) staggered to the first
?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>Also, I just noticed today, some small cracks at the
bottom of
the tailcone (down below the bottom Rudder</FONT></DIV>
<DIV><FONT size=2>pivot)...... ( I have 85 hours to date and 169 landings),
...I
know that there has been some talk of this area having a "doubler skin"
fitted....but I was hoping to </FONT><FONT size=2>"get away with not having to
do it" as I fitted a real SPRING on the tailwheel...which has lots of
"give" and allows the tail of the plane to move around "a bit"...NOT like the
solid / unmovable hunk of aluminium that was supplied with the
kit.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>Should I fabricate a doubler from .032" 6061 T6.....or
thicker....and / or from something stronger , say 2024 T3</FONT></DIV>
<DIV><FONT size=2>(and what do I do with the small cracks already in the
tailcone... (about 3/8" long), apart from stop drilling them ?)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>Any help will be gratefully received </FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>Thanks</FONT></DIV>
<DIV> </DIV>
<DIV><FONT size=2>Rick & Wendy in OZ</FONT></DIV>
<DIV><FONT size=2>541R</FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE dir=ltr
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px;
PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
<DIV style="FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV
style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color:
black"><B>From:</B>
<A href="mailto:
oifa@irishfield.on.ca" title=
oifa@irishfield.on.ca>Wayne G.
O'Shea</A> </DIV>
<DIV style="FONT: 10pt arial"><B>To:</B> <A
href="mailto:
murphy-rebel@dcsol.com"
title=
murphy-rebel@dcsol.com>
murphy-rebel@dcsol.com</A> </DIV>
<DIV style="FONT: 10pt arial"><B>Sent:</B> Thursday, 27 December 2001
15:15</DIV>
<DIV style="FONT: 10pt arial"><B>Subject:</B> Re: Firewall position</DIV>
<DIV><BR></DIV>
<DIV><FONT face=Arial size=2>Well Peter! There is the double pitched row of
rivets up the forward door post (with the top 3 or 4's pitch left as
I have recommended since the winter of 1996 FOR ANY
ENGINE
INSTALLATION (well before MAM put out the "float fix" bulletin after a
couple aircraft, including the factory Elite, were damaged at Osh
and something had to be done officially then). I can show you the
pictures of why I started doing this in 1996, next time you are
over, but
I'm not going to post them! Lets just say that the original rivet pitch
(with an O-235 engine) didn't hold up to one ski, 2 G landings on
ice!!!!
Like I keep telling you guys/gals I am rarely offering "theory" and/or
calculated loads. I am passing on specific things that I've found
necessary, to keep the thing together, from proven "destructive
some of
the stuff that has been found necessary to reinforce the Rebel over the
see most
of this and I have yet to see Robin screw up a landing
either!!!! </FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2>I really don't buy the "shorten the moment
arm to
reduce the loads on the cabin structure" bull. If the O-235 was supposed
to be
fine at the original engine position, the O-320 isn't going to make a big
difference. </FONT><FONT face=Arial size=2>The weight difference in
engines is
only about 30 pounds. If we were talking moving the engine in a foot maybe,
but not 3 inches.</FONT></DIV>
<DIV><FONT face=Arial size=2>In a (-)2.5 G (ouch!) landing that is only
75 pounds extra load (less than one extra RV1410 rivets shear strength).
I am
not going to try to figure out the load values difference on the rivets
at the top of the door post by moving the engine in 3" to 36.5",
from the
original 39.5", but will only say it's not going to make a big
difference
structurally (changes c of g significantly, but not load on door post rivets
that are in "shear"). If you have added the float fix doubler at the
top
of the post, or have done the double staggered row of rivets up the
door post (so the "guillotine" effect can't get started at the top
of the
door post and shear all the rivets out right down to the wing strut attach
fitting!) you will be fine. I can state this with confidence
only because I have tried the same "testing" on my Rebel, with the
extra
rivets up the door post and an O-320 engine, and have determined that
test) instead!!!</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>'night,</FONT></DIV>
<DIV><FONT face=Arial size=2>Wayne G. O'Shea</FONT></DIV>
<DIV><FONT face=Arial size=2><A
href="http://www.irishfield.on.ca">www.irishfield.on.ca</A></FONT></DIV>
<DIV> </DIV>
<DIV>----- Original Message ----- </DIV>
<BLOCKQUOTE dir=ltr
0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
<DIV
black"><B>From:</B>
Cowan/Lexy
9:49
PM</DIV>
<DIV style="FONT: 10pt arial"><B>Subject:</B> Firewall position</DIV>
<DIV><BR></DIV>
<DIV><FONT color=#000000 face="Bookman Old Style" size=2>In scanning the
manual (from early 90s) I see a comment that has not been mentioned that I
can recall about the reason for moving the firewall back for the heavier
engine. The reason stated is to shorten the moment arm to reduce loads on
the cabin structure. </FONT></DIV>
<DIV><FONT face="Bookman Old Style" size=2>Wayne, I don't recall you
mentioning any reinforcements that specifically address this aspect.
Have I
missed something?</FONT></DIV>
<DIV><FONT face="Bookman Old Style" size=2>Thanks</FONT></DIV>
size=2>Peter.</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
