skis / Rebel
Posted: Sat Feb 18, 2012 12:37 am
Hi Wayne,
There is snow on the ground so I am making my annual trip to your website to
look at the photo of the Rebel on skis--got to keep motivated!
I couldn't find any reference for cost of skis. I am interested in
purchasing some, but obviously I am not in any rush. Could you get me some
pricing info. and then perhaps I can get on your waiting list--I understand
it's easier to make several skis at a time and I could just wait till your
next production run.
Ski flying will be new to me. You had mentioned in past posts that these skis
could land in deep powder and were wheel penetrating skis; how well do these
work on hard pavement? Do you drag the back of the ski? Is there a
replaceable rub block on the trailing edge of the ski? Do you put plastic
bottoms on all of them? How do they mount on spring gear? Should I use
longer bolts in the gear saddles to allow for future attachment of rigging?
I did install the aft attach point for the bungee gear to use if needed.
As tires are the primary shock absorption for the aircraft, how hard on the
airframe, is landing with skis as compared to floats? I am trying to figure
out how much to beef up the airframe from stock configuration for ski
utilization. At this time I do not plan on using floats. For reference, I
am using a Jabiru 3300 engine, weighing approx. 180 lbs., wooden prop, and
basically a very light weight airframe. Aircraft empty wt. is a big concern
to me and I am trying to build it as light as possible, but don't want to
compromise strength for ski use.
I was also looking at your firewall reinforcement plates. I am thinking this
might be overkill for my situation. I also noticed in the photo that you
install motor mount bolts with the nut behind the firewall. My manual shows
the nut on the forward side of the firewall. I am assuming this is to allow
the bolts to be changed as they don't appear to be removable if installed per
MAM. I plan on using NAS 4 bolts; are number 4 bolts removeable from the
back side? The bottom half of my engine mount does have cross bracing; the
top does not. I had even thought of installing a cross brace on the top half
of the motor mount itself as I don't have any mags back there. This cross
brace could be installed later if needed. The cross brace could even use the
top two motor mount bolts as an attachment point. Do you use ST31 or ST28
for the two piece cross brace recommended by MAM? Do you put the piece on
the front of the firewall under the mount? It would seem that this would
shift the thrust line, unless you shimmed the other three to match.
As always, thank you for your time and interest in supporting Rebel builders!
No rush to respond to this--just at your convenience. I know this is a lot
of questions, but I know you would be the person who might have all the
answers. Hope your recovery is going well and you are soon up to speed and
back out in the shop!
Thanks again,
Jim R254
Thanks again,
Jim R254
