Tail wheel "rod" mount - Rebel
Posted: Sat Feb 18, 2012 12:22 am
Mike/ALL, had a look at the SR tailwheel rod spring's 3 piece bracket/eye
assembly today. I'm sure it could be used but would change the whole
mounting design requirements in the back of the Rebel (and like Keith says,
would end up being an Elite!). Would suggest anyone wanting to do this
(usage of a rod spring instead of leaf) to just manufacture a new piece as
discussed previously!
Sent: Saturday, December 08, 2001 4:36 PM
Subject: Re: Scott Tail wheel
IThanks Mike,
I'll have a look at the fin posts tail wheel "rod" bracket, on the SR that
tires.have in the shop, and see if it would be adaptable to the Rebel!
Sent: Saturday, December 08, 2001 4:28 PM
Subject: RE: Scott Tail wheel
missionPerhaps the tailwheel mount used on the Super Rebel could be used on the
Rebel. At least the nicely machined brackets and fitting with the round
hole for the tube. Save you having to machine your own.
SR#044
dasstolguy@dcsol.com
Sent: Friday, December 07, 2001 4:59 PM
Subject: Scott Tail wheel
I am deciding on features for a Rebel kit before prices go up. Theis
Intermediate bush (wheels) eventually floats; thinking 8.5-6 main
**withIn
the Aircraft Spruce catalog, Scott tailwheels model 3200 and 3400 are
offered.
The catalog states that the 3400 is more heavy duty ?designed for use**tube spring mounting?.
Questions:
1)
Is tube spring mounting possible on a Rebel? How?
2)
Pros cons of tube spring vs leaf spring?
3)
Pros cons of model 3200 vs 3400?
4)
Tips on matching tailwheel to mains?
5)
Would tailwheel selection affect main gear selection ( bungee, coil,
spring)?
Rob Sexmith
Cincinnati to Killarney ON or bust
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com**
