Interesting math
Posted: Fri Feb 17, 2012 9:22 pm
I just did some math that brought some very interesting results.
Everyone knows that prop redlines are generally in the 2700 RPM range. And
I have found out from more than one source that a Chevy V8 should probably
be redlined at 4500 RPM for maximum reliability. So I came up with a 1.67:1
reduction ratio based on these figures. Applying 75% to the engine redline
gives me a cruise prop RPM with a 1.67:1 reduction of 2021 RPM. Here's the
interesting thing I found out by running some more numbers.
Assume max engine RPM of 4000 and max prop RPM of 2700:
4000/2700=1.48 gear reduction
4000*75%=3000 cruise engine RPM/1.48=2027 cruise prop RPM
Assume max engine RPM of 4500 and max prop RPM of 2700:
4500/2700=1.67 gear reduction
4500*75%=3375 cruise engine RPM/1.67=2021 cruise prop RPM
Assume max engine RPM of 5000 and max prop RPM of 2700:
5000/2700=1.85 gear reduction
5000*75%=3750 cruise engine RPM/1.85=2027 cruise prop RPM
Assume max engine RPM of 5500 and max prop RPM of 2700:
5500/2700=2.04 gear reduction
5500*75%=4125 cruise engine RPM/2.04=2022 cruise prop RPM
Just for fun Assume max engine RPM of 3000 and max prop RPM of 2700:
3000/2700=1.11 gear reduction
3000*75%=2250 cruise engine RPM/1.11=2027 cruise prop RPM
Is there something wrong with my math or do I get essentially the same
cruise prop RPM no matter what engine redline I choose? Don't I get the
same thrust from the prop if 100 HP is turning it at 2020 RPM versus 200 HP
turning it at 2020 RPM? Maybe therein lies the problem. Perhaps 100 HP
can't turn the prop at 2020 RPM if it's an 80 inch three bladed monster.
SR #044
SR #044
