Wingtip and W-609
Posted: Fri Feb 17, 2012 9:22 pm
I've encountered an interesting problem preparing the sub-assembly for the
right wingtip. W-609 is about 3/4" too short for W-606R to clear the aileron
spade. I assume this is because the rib flanges on the right wing face
outward, so W-609 is seated further inward by the length of the rib flange.
Should I rivet on a small extension to W-609 on which to rivet W-606R to
insure the proper clearance? Or should MAM be supplying W-609s in right and
left versions?
The manual is a little vague in calling out the trimming of the wingtip
itself. Obviously the bottom only gets trimmed in the spade area, but there
is a whole lot more than 12" (as the manual calls for) from the front of the
spade to the trailing edge of the aileron.
Happy Thanksgiving!
Jeffrey Steenson
Elite #714
left versions?
Happy Thanksgiving!
Jeffrey Steenson
Elite #714
