Possible screwup - Bulkhead F
Posted: Sat Feb 18, 2012 12:22 am
Hello folks,
Please help! When constructing my bulkhead F - according to my manual dated
1993, it says in step 158:
"Cleco two round bulkhead sections to fus-39 and fus-24's. Figure 63."
My fus-39 has no flanges on it, just a single row of holes down each side.
There was only one possible way to cleco the bulkhead quarters to fus-39 so
I built it that way. Here is a picture:
http://www.spyparts.com/users/jj/Rebel/BulkheadF.jpg
My bulkhead F is completed and riveted to fuse-39. Fuse-39 is already
riveted to the next bulkhead back where the float attach fittings are. I am
making the three half bulkheads that go between the F bulkhead and the front
carrythrough and I notice - The bottom of Bulkhead F is almost an inch wider
than the top! The cage assy, the top of F and A bulkheads are 44", the
bottom of F is nearly 45". The cutouts in bulkhead A straddle the row of
holes in fus-39 like in this picture:
http://www.spyparts.com/users/jj/Rebel/fus-39rear.jpg
As you saw in the first pix the cutouts on bulkhead F are outboard of the
row of holes and that was the only way to cleco it as the manual said. This
does not look right to me. If it's wrong I need a plan to remedy this.
Would it be acceptable to cut out a 1/2" section of F right over the cutouts
on both sides and slap a doubler over it? Any other suggestions?
Thanks!
Joel Jacobs
Rebel 416
Thanks!
Joel Jacobs
Rebel 416
